Discovery trouble
  • hpeti2
    • Jul 2015
    • 29
    Discovery trouble
    Hi all!
    I have a very annoying trouble with discovery function. We have 2 HP servers:
    dl160-1 (IPs 10.12.64.11 and 10.12.64.105) and dp160-2 (IPs 10.12.64.12 and 10.12.64.106). I made a discovery rule with these ip ranges:
    10.12.64.80-200,
    10.12.64.5-13,
    10.12.64.15-19,
    10.12.64.21-80
    with these checks:
    - Zabbix agent "agent.hostname"
    - Zabbix agent "system.uname"
    and with these Device uniqueness criterias:
    - IP address
    The discovery rule find every time all of 4 IP address as dl160-1's IPs and I can not delete permanently unwanted/wrong addresses.
    Zabbix 3.0.3
  • onallion
    • Mar 2016
    • 131
    Check the host name in your Zabbix Agent configuration files on the servers. Perhaps they both have the host as "dl-1601"
    • hpeti2
      • Jul 2015
      • 29
      Hostnames are same (we have about 20 servers with this hostname without any problem), but not equal to dp-dl160-1. Due to same hostname parameter that I set 3 device uniqueness criteria.
      • onallion
        • Mar 2016
        • 131
        You can only choose one device uniqueness criteria
        • hpeti2
          • Jul 2015
          • 29
          Sorry yes you are right. I chose Zabbix agent "system.uname", because this parameter is individual.
