Zabbix Agent 2 receiving MQTT messages but not receiving them in server
  • palge
    • Sep 2024
    Issue: Subscribed MQTT Values not arriving in Zabbix Server.
    I have configured an item to get messages published via mqtt
ID:	490891Zabbix agent log showes that the agent subscribed and is receiving values:
    Latest Data im Zabbix WebGui does not show anything:
ID:	490894But ​​I'm receiving other values for the same host:
    zabbix_agent2.conf
    PidFile=/run/zabbix/zabbix_agent2.pid
    LogFile=/var/log/zabbix/zabbix_agent2.log
    LogFileSize=512
    DebugLevel=5
    Server=127.0.0.1
    ListenPort=10050
    ServerActive=127.0.0.1:10051
    HostnameItem=system.hostname
    RefreshActiveChecks=300
    BufferSend=3600
    BufferSize=256
    Plugins.MQTT.Default.Url=tcp://localhost:1883
    Plugins.MQTT.Default.User=zabbix
    Plugins.MQTT.Default.Password=securepassword
    Versions
    zabbix_server (Zabbix) 7.0.3
    zabbix_agent2 (Zabbix) 7.0.3
    Revision d93ce022627 19 August 2024, compilation time: Aug 19 2024 11:20:25, built with: go1.22.6
    Plugin communication protocol version is 6.4.0
    Plugin used: https://www.zabbix.com/integrations/mqtt#mqtt
    I tried without success:
    - Delete template and add it again
    - Restarted everything multiple times
    - Checked Debug Logs
    Does anyone has an idea?​
