Eventlog Monitor
  • Agasef
    • Sep 2024
    Eventlog Monitor
    I want to see logon failed logs based on Event ID 4776. For this, I wrote an item in the template:
    eventlog[Security,,,,4776,,skip]
    and I wrote the trigger:
    logeventid(/BSEDC18/eventlog[Security,,,,4776,,skip])=1
    If the trigger works, the action does not work. Mail does not receive an alert that there is a problem.
  • kamil1
    • Aug 2024
    • 40
    Couple of hints you might want to check:
    • Modify the trigger to explicitly check for Event ID 4776 with logeventid: {BSEDC18:eventlog[Security,,,,4776,,skip].logeventid(4776)}=1
    • Ensure the severity of the trigger matches the action’s conditions.
    • Review action configuration and ensure email settings are correct.
    • Check Zabbix server logs for any errors related to the action or trigger.
    • Test with a known event to confirm the alerting system works.
