Zabbix is unable to check Veeam REST API
  • Wowa
    • Sep 2024
    I'm trying to set up "Veeam Backup and Replication by HTTP" in Zabbix 7.0+ and Veeam 12+ (Enterprise Plus, API included)
    1) I created a user in Veeam and entered the credentials and Veeam server address as required in the guide.
    I get an error when I try to test the template
    {"error":"Error: cannot get URL: Couldn't connect to server."}
    2) I found a similar topic on the forum and tried to execute the commands given in the topic to check the operability from the console of the Zabbix server itself (https://www.zabbix.com/forum//zabbix...veeam-rest-api)
    HTML Code:
    curl -k -H 'x-api-version: 1.0-rev2'  'Content-Type: application/x-www-form-urlencoded' --data 'grant_type=password&username=veeamUserLogin&password=veeamUsrPass' 'https://ip_veeam:9419/api/oauth2/token'
    curl -k -H 'x-api-version: 1.0-rev2'  'Authorization: Bearer TOKEN_FROM_PREVIOUS_REQUEST' https://ip_veeam:9419/api/v1/jobs/states
    with key
    ----insecure
    or
    -k
    the request is executed and I get the token
    but without this key i get ​error:
    curl: (3) URL using bad/illegal format or missing URL
    curl: (60) SSL: certificate subject name 'Veeam Backup Server Certificate' does not match target host name '192.168.x.x'
    More details here: https://curl.se/docs/sslcerts.html
    curl failed to verify the legitimacy of the server and therefore could not
    establish a secure connection to it. To learn more about this situation and
    how to fix it, please visit the web page mentioned above.
    3) I tried to add the certificate to trusted, but the self-signed certificate does not match the internal IP address.
    Alternatively, I'm considering issuing a new certificate with an IP address for Veeam, but that may cause the backup to fail. Or set up monitoring via the https://github.com/romainsi/zabbix-VB-R-SQL template.
  • tompaah
    • Jan 2025
    • 20
    Got the exact same problem - did you get this resolved?
    Works perfectly in my test environment that is a Zabbix Appliance.
    But in production, that is a Zabbix installed with packages on Rocky, it does not.
    From CLI it's able to connect to Veeam API with
    curl -vk https://veeam-name:9419
    It's clearly visible from there the certificate is self-signed.
    But from the Zabbix check it just doesn't connect.
    I'd hope there yould be a "skip TLS verify" option somewhere. But where and why does it work out of the box on the appliance..?
    • tompaah
      • Jan 2025
      • 20
      Appears to be a problem created by SELinux.
      After setting the variable
      sudo setsebool nis_enabled true
      the Veeam checks worked fine.
