Created a template with an item and the item is not pulling data in the front end
  • nivethaa
    • Sep 2024
    • 11
    Hello All ,
    I created a template and an item with alias for vfs.fs.get . The data for this item is not being populated in the front end . There is another template with a different alias for the same vfs.fs.get which pulls data for the host . But this newly created template does not pull data . I see the key is being processed in the logs .
    Alias=mysqldba2:vfs.fs.get
    {"key":"mysqldba2","itemid":425084,"delay":"1m" ,"l astlogsize":0,"mtime":0,"timeout":"4s"}]}
    What might be the issue here ?
    Thank you,
    Nivethaa
  • kamil1
    • Aug 2024
    • 40
    Can you increase the DebugLevel to at least 4 in the agent and server config and see if logs say us anything else?
    I would also suggest to test the item manually from Zabbix server:
    zabbix_get -s <host_ip> -k mysqldba2:vfs.fs.get
    Does it work?
