After updating one of our debian 12 Servers to Linux 6.1.0-25-amd64 x86_64 one of our SMART-checks will not stop running. We have disabled the item responsible for the check, now even Unlinked the whole SMART-Template for the host but it still keeps on checking.
Part of journal:
Watching the log after restarting the service shows that it sometimes starts spamming almost instantly after restarting and sometimes takes almost 30 min to start.
We had no issue with the check prior to the kernel upgrade. The check does not fail when run manually.
Any help is appreciated!
Part of journal:
... Sep 17 16:06:03 log sudo[2175574]: zabbix : PWD=/ ; USER=root ; COMMAND=/usr/sbin/smartctl -a /dev/sda -d cciss,0 -j Sep 17 16:06:03 log sudo[2175574]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1117) Sep 17 16:06:03 log sudo[2175578]: zabbix : PWD=/ ; USER=root ; COMMAND=/usr/sbin/smartctl -a /dev/sda -d cciss,0 -j Sep 17 16:06:03 log sudo[2175578]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1117) Sep 17 16:06:03 log sudo[2175575]: zabbix : PWD=/ ; USER=root ; COMMAND=/usr/sbin/smartctl -a /dev/sda -d cciss,0 -j Sep 17 16:06:03 log sudo[2175575]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1117) Sep 17 16:06:03 log sudo[2175577]: zabbix : PWD=/ ; USER=root ; COMMAND=/usr/sbin/smartctl -a /dev/sda -d cciss,0 -j Sep 17 16:06:03 log sudo[2175577]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1117) Sep 17 16:06:03 log sudo[2175450]: pam_unix(sudo:session): session closed for user root Sep 17 16:06:03 log sudo[2175583]: zabbix : PWD=/ ; USER=root ; COMMAND=/usr/sbin/smartctl -a /dev/sda -d cciss,0 -j Sep 17 16:06:03 log sudo[2175583]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1117) Sep 17 16:06:03 log sudo[2175467]: pam_unix(sudo:session): session closed for user root ...
