Problem with charts decriptions after upgrade to Zabbix 7.0.
  • d0N91
    • Jan 2020
    • 9
    I have problem with chart (classic) and charts generated in templates. After Zabbix upgrade from 5.4 to 7.0 charts looks like this
    Descirption are showing up but date/time are some kind of icons.
    Ubuntu 24
    PostgreSQL 16
    PHP 8.3
    Apache
    I was already reinstall Apache, Zabbix-Frontend-PHP, PHP and still same view.
    Apache logs doesn't shows any errors.
    Have you encountered anything like this?
  • d0N91
    • Jan 2020
    • 9
    Anyone have any idea?
    • Jason
      • Nov 2007
      • 431
      Are you on the latest? There's lots of graph fixes in 7.0.3? https://www.zabbix.com/rn/rn7.0.3
      • d0N91
        • Jan 2020
        • 9
        Yes, I'm on latest version - 7.0.3.
        Upgrade to 7.0.4RC1 doesn't change anything.
        • d0N91
          • Jan 2020
          • 9
          On Ubuntu 22.04 everything works fine. The problem appear after upgrade to Ubuntu 24.04. I can't find any clue in logs. Probably i'll stay at Ubuntu 22.04.
          • Jason
            • Nov 2007
            • 431
            selinux or apparmor?
            • d0N91
              • Jan 2020
              • 9
              I Was testing with both disable, nothing change.
              • Jason
                • Nov 2007
                • 431
                Is php version the same in both? All modules installed?
                • d0N91
                  • Jan 2020
                  • 9
                  First I have tested PHP 8.0, next I was tried 8.4 same effect. On 22.04 works fine, on 24.04 not. I checked all modules and it looks fine.
