Oracle Template by Zabbix agent 2
  • studero
    • Aug 2023
    • 84
    Hi all,
    Steps to reproduce:
    1. Add Template Oracle Agent 2 to the client
    2. Set user, password, connection
    Result:
    After apply, I have the following message into the log file on the Zabbix server.
    284267:20240925:134102.254 item "svx-ora-16e - co11916e oracle.tbs_max_bytes["HBI1","ACTIVITI"]" became not supported: Preprocessing failed for:
    284267:20240925:134105.249 item "svx-ora-16e - co11916e oracle.tbs_max_bytes["HBI1","UNIFR_LIFE"]" became not supported: Preprocessing failed for:
    284267:20240925:134918.505 item "svx-ora-16e - co11916e oracle.tbs_max_bytes["HBI1","FAC_APPS"]" became not supported: Preprocessing failed for:
    284267:20240925:134921.254 item "svx-ora-16e - co11916e oracle.tbs_max_bytes["HBI1","FAC_PLA"]" became not supported: Preprocessing failed for:
    284267:20240925:134927.255 item "svx-ora-16e - co11916e oracle.tbs_max_bytes["HBI1","FAC_APPS_HISTO"]" became not supported: Preprocessing failed for:
    And this following error message on the web console:
    1. Failed: cannot extract value from json by path "$..['FAC_APPS'].status.first()": invalid object format, expected opening character '{' or '[' at: ''
    I need help
    Regards
    Olivier
  • mfortes
    • Oct 2019
    • 417
    Do u apply every privilege necessary on this orac user?
    Michael R. Fortes
    Linkedin: Mike Fortes
    Medium: mromeiro-f
    • studero
      • Aug 2023
      • 84
      Normally yes, as following:
      CREATE USER ZABBIX
      IDENTIFIED BY <password>
      HTTP DIGEST DISABLE
      DEFAULT TABLESPACE USERS
      TEMPORARY TABLESPACE TEMP
      PROFILE DBA
      ACCOUNT UNLOCK;
      -- 1 Role for ZABBIX
      GRANT CONNECT TO ZABBIX CONTAINER=ALL;
      ALTER USER ZABBIX DEFAULT ROLE ALL;
      -- 11 System Privileges for ZABBIX
      GRANT CREATE SESSION TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY CUBE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY CUBE BUILD PROCESS TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY CUBE DIMENSION TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY DICTIONARY TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY MEASURE FOLDER TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY MINING MODEL TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY SEQUENCE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY TABLE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ANY TRANSACTION TO ZABBIX CONTAINER=ALL;
      GRANT SET CONTAINER TO ZABBIX CONTAINER=ALL;
      -- 25 Object Privileges for ZABBIX
      GRANT SELECT ON SYS.DBA_DATA_FILES TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_FREE_SPACE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_SCHEDULER_JOB_LOG TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_TABLESPACES TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_TABLESPACE_USAGE_METRICS TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_TEMP_FILES TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.DBA_USERS TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.GV_$SORT_SEGMENT TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$ACTIVE_SESSION_HISTORY TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$ARCHIVE_DEST TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$ASM_DISKGROUP TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$DATABASE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$DATAFILE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$INSTANCE TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$LOG TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$OSSTAT TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$PARAMETER TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$PGASTAT TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$PROCESS TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$RECOVERY_FILE_DEST TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$RESTORE_POINT TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$SESSION TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$SGASTAT TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$SYSMETRIC TO ZABBIX CONTAINER=ALL;
      GRANT SELECT ON SYS.V_$SYSTEM_PARAMETER TO ZABBIX CONTAINER=ALL;
      -- 1 Container Data Restriction for ZABBIX
      ALTER USER ZABBIX
      SET CONTAINER_DATA = ALL
      CONTAINER = CURRENT;
