Zabbix agent and proxy
  • Cordeos
    • Sep 2024
    The recent Zabbix agent and proxy packages 6.0.34-release1.el8.x86_64 appear to have been released without TLS components compiled in.
    After our 6am automated DNF update of Rocky Linux 8 machines, we suddenly have a dozen Zabbix agent/proxy machines unable to start these components.
    -- Unit zabbix-proxy.service has begun starting up.
    Sep 27 08:40:22 xxx.abc.com zabbix_agentd[8437]: zabbix_agentd [8437]: "TLSConnect" configuration parameter cannot be used: Zabbix agent was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_agentd[8437]: zabbix_agentd [8437]: "TLSAccept" configuration parameter cannot be used: Zabbix agent was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_agentd[8437]: zabbix_agentd [8437]: "TLSPSKIdentity" configuration parameter cannot be used: Zabbix agent was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_agentd[8437]: zabbix_agentd [8437]: "TLSPSKFile" configuration parameter cannot be used: Zabbix agent was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com systemd[1]: zabbix-agent.service: Control process exited, code=exited status=1
    Sep 27 08:40:22 xxx.abc.com systemd[1]: zabbix-agent.service: Failed with result 'exit-code'.
    -- The unit zabbix-agent.service has entered the 'failed' state with result 'exit-code'.
    Sep 27 08:40:22 xxx.abc.com systemd[1]: Failed to start Zabbix Agent.
    -- Subject: Unit zabbix-agent.service has failed
    Sep 27 08:40:22 xxx.abc.com zabbix_proxy[8438]: zabbix_proxy [8438]: "TLSConnect" configuration parameter cannot be used: Zabbix proxy was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_proxy[8438]: zabbix_proxy [8438]: "TLSAccept" configuration parameter cannot be used: Zabbix proxy was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_proxy[8438]: zabbix_proxy [8438]: "TLSPSKIdentity" configuration parameter cannot be used: Zabbix proxy was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com zabbix_proxy[8438]: zabbix_proxy [8438]: "TLSPSKFile" configuration parameter cannot be used: Zabbix proxy was compiled without TLS support
    Sep 27 08:40:22 xxx.abc.com systemd[1]: zabbix-proxy.service: Control process exited, code=exited status=1
    Sep 27 08:40:22 xxx.abc.com systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    -- The unit zabbix-proxy.service has entered the 'failed' state with result 'exit-code'.
    Sep 27 08:40:22 xxx.xxx.com systemd[1]: Failed to start Zabbix Proxy.
    -- Subject: Unit zabbix-proxy.service has failed
    DNF History output:
    Upgrade zabbix-agent-6.0.34-release1.el8.x86_64 @zabbix
    Upgraded zabbix-agent-6.0.33-release2.el8.x86_64 @@System
    Upgrade zabbix-proxy-mysql-6.0.34-release1.el8.x86_64 @zabbix
    Upgraded zabbix-proxy-mysql-6.0.33-release2.el8.x86_64 @@System
    Upgrade zabbix-selinux-policy-6.0.34-release1.el8.x86_64 @zabbix
    Upgraded zabbix-selinux-policy-6.0.33-release2.el8.x86_64 @@System
    Upgrade zabbix-sql-scripts-6.0.34-release1.el8.noarch @zabbix
    Upgraded zabbix-sql-scripts-6.0.33-release2.el8.noarch @@System
  • Cordeos
    • Sep 2024
    Sorry, tried to fix the title but not authorized. Could an admin or moderator please change to: Zabbix agent and proxy Zabbix agent and proxy
    Zabbix Agent and Proxy REDHAT/CentOS 6.0.34-release1 Not Compiled with TLS Support
    • Cordeos
      • Sep 2024
      Cant fix the test of that second post either.
      what a waste of time - giving up trying to notify anyone at ZABBIX!
        • 5004
        This has been reported
