RHEL 7 & Amazon Linux??
  • joshuamcdo
    • Nov 2013
    • 76
    What is going on? I need to install a quick Zabbix demo like I have in the past and everything is busicated all over the place.
    When trying to install on Amazon linux I get these errors:
    Error: httpd24-tools conflicts with httpd-tools-2.2.31-1.8.amzn1.x86_64
    Error: php56-common conflicts with php-common-5.3.29-1.8.amzn1.x86_64
    Error: Package: iksemel-1.4-2.el7.centos.x86_64 (zabbix-non-supported)
    Requires: libgnutls.so.28()(64bit)
    Error: Package: zabbix-server-mysql-3.0.7-1.el7.x86_64 (zabbix)
    Requires: systemd
    Error: php56 conflicts with php-5.3.29-1.8.amzn1.x86_64
    Requires: libnetsnmp.so.31()(64bit)
    Error: php56-cli conflicts with php-cli-5.3.29-1.8.amzn1.x86_64
    Requires: libgnutls.so.28(GNUTLS_1_4)(64bit)
    Error: httpd24 conflicts with httpd-2.2.31-1.8.amzn1.x86_64
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    When trying to install on RHEL 7 I get missing php packages that I can't seem to find.
    "php-mbstring" & "php-bcmath"
    I have tried everything I know to do and googled and read and can't seem to find a resolution to these issue.
    Please HELP!
  • kloczek
    • Jun 2006
    • 1771
    Amazon Linux is not compatible with RHEL (any number).
    You are mixing two sets of packages which are not binary compatible.
    • joshuamcdo
      • Nov 2013
      • 76
      So...
      I tried just using EPEL and it says there are no packages available. I don't recall having these problems in the past. So confused..
      Thanks in advance.
      • Atsushi
        • Aug 2013
        • 2028
        You can not install packages for RHEL 7 on Amazon Linux.
        Dependent packages and versions are different.
        You will be able to install packages for RHEL 6.
        However, some functions can not be used because they are built with dependencies of old libraries.
        If you want to use all functions of Zabbix 3.0 or later, you should rebuild it on Amazon Linux.
        My srpm of Zabbix 3.0.6 is in the following URL.
        Sorry, The explanation is Japanese only.
        • joshuamcdo
          • Nov 2013
          • 76
          I get that I can't install RHEL 7 version on Amazon linux. I have tried installing it on both platforms and the RHEL 7 install doesn't work either. I built an instance with RHEL 7, added the RHEL 7 zabbix repo and tried to install. I get the error messages that "php-mbstring" & "php-bcmath" cannot be founda and the only way around that I find installs php7 which doesn't work.
          #cat /etc/redhat-release
          Red Hat Enterprise Linux Server release 7.3 (Maipo)
          yum -y update
          reboot
          rpm -ivh https://dl.fedoraproject.org/pub/epe...t-7.noarch.rpm
          rpm -ivh http://repo.zabbix.com/zabbix/3.0/rh...el7.noarch.rpm
          yum -y install zabbix-server-mysql zabbix-web-mysql mysql mariadb-server httpd php
          Loaded plugins: amazon-id, rhui-lb, search-disabled-repos
          epel/x86_64/metalink | 16 kB 00:00:00
          epel | 4.3 kB 00:00:00
          zabbix | 951 B 00:00:00
          zabbix-non-supported | 951 B 00:00:00
          (1/3): epel/x86_64/group_gz | 170 kB 00:00:00
          (2/3): epel/x86_64/primary_db | 4.5 MB 00:00:00
          (3/3): epel/x86_64/updateinfo | 732 kB 00:00:00
          (1/2): zabbix-non-supported/x86_64/primary | 1.6 kB 00:00:00
          (2/2): zabbix/x86_64/primary | 15 kB 00:00:00
          zabbix 105/105
          zabbix-non-supported 4/4
          Resolving Dependencies
          --> Running transaction check
          ---> Package httpd.x86_64 0:2.4.6-45.el7 will be installed
          --> Processing Dependency: httpd-tools = 2.4.6-45.el7 for package: httpd-2.4.6-45.el7.x86_64
          --> Processing Dependency: /etc/mime.types for package: httpd-2.4.6-45.el7.x86_64
          --> Processing Dependency: libapr-1.so.0()(64bit) for package: httpd-2.4.6-45.el7.x86_64
          --> Processing Dependency: libaprutil-1.so.0()(64bit) for package: httpd-2.4.6-45.el7.x86_64
          ---> Package mariadb.x86_64 1:5.5.52-1.el7 will be installed
          --> Processing Dependency: /usr/bin/perl for package: 1:mariadb-5.5.52-1.el7.x86_64
          --> Processing Dependency: php-mbstring for package: zabbix-web-3.0.7-1.el7.noarch
          --> Processing Dependency: php-bcmath for package: zabbix-web-3.0.7-1.el7.noarch
          --> Finished Dependency Resolution
          Error: Package: zabbix-web-3.0.7-1.el7.noarch (zabbix)
          Requires: php-mbstring
          Requires: php-bcmath
          Thoughts?
          Thanks in advance,
          JMCD
          • joshuamcdo
            • Nov 2013
            • 76
            I figured a way around it.. although I shouldn't have had to do this..
            wget http://mirror.centos.org/centos/7/os...el7.x86_64.rpm
            yum install php-common
            rpm -ivh *.rpm
            Thanks,
            yum -y update
            reboot
            zabbix 105/105
            Thoughts?
            Thanks in advance,
            JMCD
            • Atsushi
              • Aug 2013
              • 2028
              When using RHEL, you need to enable the Optional repository.
              If it is RHEL 7 on EC2, please execute the following command line.
              $ sudo yum-config-manager --enable rhui-REGION-rhel-server-optional
              I think that installing CentOS package on RHEL became out of support of Redhat.
              • joshuamcdo
                • Nov 2013
                • 76
                That doesn't work on EC2 instances+RHEL. There is something goofy about the way they handle their channels. I opened a ticket with amazon support to understand what I needed to do to get those packages and all they wanted to do was pass the blame to zabbix no matter how I tried to make them understand.
                Thanks,
