Script with user input access denied for users
  • marek.vesely@direct.cz
    • Apr 2024
    when I cal script which has user input, it calls Zabbix api: ?action=script.userinput.edit. But this api is available by default only for super admin users. So users with User and Admin roles getting access denied if they want to run script with manual input. Is there plan to fix this and add to lower roles permission to this api?
    Thank you,
    Marek
  • Answer selected by [email protected] at 17-10-2024, 10:23.
    Ldzzzz
    • Feb 2024
    • 16
    Yes, you can add permission to any role you want. Just go to role settings and activate the feature :
    You can filter the actions allowed by API if you wish.
    Don't forget to create a user token if needed:
    • Ldzzzz
      • Feb 2024
      • 16
