Regular expression in Post-procesing steps and JSONPath
  • Rudlafik
    • Nov 2018
    • 168
    I have this JSON:
    {"{#INSTANCE}": "HarddiskVolume1"},
    {"{#INSTANCE}": "HarddiskVolume2"},
    {"{#INSTANCE}": "C:"},
    {"{#INSTANCE}": "E:"},
    {"{#INSTANCE}": "F:"},
    {"{#INSTANCE}": "_Total"}
    When I try this code "A": $..[?(@['{#INSTANCE}'] =~ ":")].['{#INSTANCE}']
    Result is:
    ["C:","E:","F:"]​
    When I try this code "B" with regular expression: $..[?(@['{#INSTANCE}'] =~ /\w:/)].['{#INSTANCE}']
    Result is ERROR:
    HTML Code:
    cannot extract value from json by path "$..[?(@['{#INSTANCE}'] =~ /\w:/)].['{#INSTANCE}']": unsupported construct in jsonpath starting with: "/\w:/)].['{#INSTANCE}']"
    When i tested code "B" in this walidator test is OK: https://www.site24x7.com/tools/json-path-evaluator.html
    Where is problem? (ZBX 6.4.18)
  • kamil1
    • Aug 2024
    • 40
    Please, try to verify agains
    Looks like the syntax you used might not be supported.
