Zabbix Agent brings me some random services which are not running
  • Toorms
    • Dec 2022
    • 11
    Hello Community,
    since I installed the Zabbix Agent (also the same problems with Zabbix Agent 2) the agent gives me some messages about services which are supposedly not running. But when I'm looking for the service in the Windows 11 virtual machine, I got nothing about it. So the service does not even exists.
    Is there anything to do in the configruation file to throw theses messages away?
    PS C:\Windows\system32> Get-Service | Where-Object {$_.displayName.StartsWith("webthreatdefusersvc_4bfb96a")} | Select name
    • 5004
    That "_128b6b" part refers to a service started up by a user session. It changes ... You need to edit the template macro ({$SERVICE.NAME.NOT_MATCHES}) to ignore those services with regex patterns... i.e "cbdhsvc_.*" Then discovery will not pick them up and you will not have useless triggers.
    • Toorms
      • Dec 2022
      • 11
      Is this correct?
      ^(?:RemoteRegistry|MMCSS|gupdate|SysmonLog|clr_optimization_v.+|sppsvc|gpsvc|Pml Driver HPZ12|Net Driver HPZ12|MapsBroker|IntelAudioService|Intel\(R\) TPM Provisioning Service|dbupdate|DoSvc|CDPUserSvc_.+|WpnUserService_.+|OneSyncSvc_.+|WbioSrvc|BITS|tiledatamodelsvc|GISvc|ShellHWDetection|TrustedInstaller|TabletInputService|CDPSvc|wuauserv|.+_.+)$
      Or what is the correct regex for that? Did you have an example for me?
      The other thing is, how can I clear the current useless trigger warnings? Renew the whole host?
