API - Incorrect item key
  • dddbox
    • Feb 2017
    Hello all,
    I'm trying to create a trigger with API, it's return:
    Incorrect item key \"icmpping[187.117.123.107,100, 20, 256, 60]\" provided for trigger expression on \"187.117.123.107\"
    resp = self.zapi.trigger.create({
    'hostid': 10102,
    'description': 'Host 187.117.123.107 PING problem',
    'status' : 0,
    'type' : 3,
    'priority' : 3,
    'expression' : '{187.117.123.107:icmpping[187.117.123.107,100, 20, 256, 60].last()}=0'
    My hostname is same as IP address, 187.117.123.107.
    Also created an item associated with this host using API call, it's working.
    When I create a new trigger with the same expression in the web interface, it's working fine.
    Thanks in advance.
    Diego
  • dddbox
    • Feb 2017
    It's my mistake, an empty space in the expression. =/
    Thanks.
