zabbix 7 does not accept anymore LLD macros in delay parameter
  • giotto69
    • Jan 2011
    Hello all,
    we are no more able to use LLDMacros in items delay parameter in Zabbix 7.
    It complains it is not a correct time format; of course it is not since it's a macro of the form {#LLDMACRO}.
    Documentation states that LLD Macros are supported in delay parameter but it seems to be no more true in 7.
    does anyone have info about that?
    Giorgio
  • Answer selected by giotto69 at 08-05-2025, 10:12.
    guytarr
    • Apr 2025
    Originally posted by cyber
    Asynch polling has nothing to do with LLD being there or not... It is the way how pollers work, but all the discovery is still run before all that, all he items are prepared before all that..
    back to question... yes, docs say LLD macros are supported in item update interval field. There is a footnote for that...
    Is this, how your time intervals are set up?
    I found this ticket, it's just a small UI bug
    Until a fix, we can force through API or SQL
    We use files that Zabbix reads on the servers to delegate the creation of certain monitoring types by LLD and the frequency is defined by the team that populates the file (so 2m, 1h, 5m etc...) : for example, a file with the targets, port and frequency (and some others things usefull for the trigger and tags) that will generate net.tcp.port items
    You're right : this has nothing to do with pollers (async or not) in our case ​
    • guytarr
      • Apr 2025
      Same problem here. It's just an UI issue, forcing an ldd macro with SQL and it works !
      • mrnobody
        • Oct 2024
        • 61
        New pollers have been created to use walk and get items (like in cmd line tests), with dependent items (Asynchronous data collection \m/) to improve this kind of feature. So, LLD may be deprecated (7.0>) and it's first signal of that a see.
        Would you/we/us recreate your/ours templates to use new faster and furious features?
        Or stay on "KISS" LDD and force it usage in DB (Synchronous data collection)?
        Choose your destiny.
          • 5004
          Footnotes
          1 In the fields marked with 1 a single macro has to fill the whole field. Multiple macros in a field or macros mixed with text are not supported.
          • guytarr
            • Apr 2025
            • giotto69
              • Jan 2011
              Hi guys
              thanks for your feedbacks.
              One more workaround to assign macros is exporting the tempate with a "correct" time unit, change the template (json , yaml or whatever) and re-import.
