The nginx configuration file is missing
  • cfoucher
    • Oct 2024
    On a debian 11 server, nginx is up and running. I ran the following command.
    [FONT=Courier New]apt install zabbix-nginx-conf[/FONT]
    The expected file /etc/zabbix/nginx.conf is missing.
    What can I do to complete the setup?
    • 5004
    I don't there is such a file you are looking for...
    You are looking for the zabbix config file for nginx? That should me in /etc/nginx/conf.d/zabbix.conf
    • cfoucher
      • Oct 2024
      The file should be in /etc/zabbix and a symbolic link in /etc/nginx should point to it.
        • 5004
        Fine, I stand corrected, for debians/ubuntus it seems a bit different ... (unpacked a .deb for ubuntu 22.04 to check...)
        dpkg -c zabbix-nginx-conf_1%3a7.0.5-1+ubuntu22.04_all.deb
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./etc/
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./etc/zabbix/
        -rw-r--r-- root/root      1978 2024-10-21 15:46 ./etc/zabbix/nginx.conf
        -rw-r--r-- root/root       564 2024-10-21 15:46 ./etc/zabbix/php-fpm.conf
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./usr/
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./usr/share/
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./usr/share/doc/
        drwxr-xr-x root/root         0 2024-10-21 15:46 ./usr/share/doc/zabbix-nginx-conf/
        -rw-r--r-- root/root      5949 2024-10-21 15:46 ./usr/share/doc/zabbix-nginx-conf/changelog.Debian.gz
        -rw-r--r-- root/root       301 2024-10-21 15:46 ./usr/share/doc/zabbix-nginx-conf/copyright
        But if you intalled and it is not there, then maybe your installation failed and you should try again...
        • cfoucher
          • Oct 2024
          I have found a solution by running the installation on another server, then copying the configuration file to the target server.
          Thanks for your help.
