The initial sql schema is missing
  • cfoucher
    • Oct 2024
    As described in the installation instructions, I ran the following command on a debian server.
    apt install zabbix-server-mysql zabbix-frontend-php zabbix-nginx-conf zabbix-agent
    Then, in order to import initial schema and data, I ran the following.
    zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbix​
    This failed because the file /usr/share/doc/zabbix-server-mysql/create.sql.gz is missing.
    • 5004
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    it says to use "server.sql.gz"... not create.sql.gz... It would be good to use up to date instructions...
    • cfoucher
      • Oct 2024
      Thank you for your answer. I forgot to mention that I was trying to install the release 5.0 LTS. The instructions for that release are to use `create.sql.gz`.
      Installation instructions: https://www.zabbix.com/fr/download?zabbix=5.0&os_distribution=debian&os_vers ion=11&components=server_frontend_agent&db=mysql&w s=nginx
      Anyway, I found a file named `/usr/share/zabbix-server-mysql/schema.sql.gz`. I used it and followed the next installation steps.
      Once complete, the server frontend is asking to "Configure DB connection" only leaving the PostgreSQL option.
      How can I select mysql?
