Security Vulnerabilities in Zabbix Version 6.2.0
  • GJ-InfoSec
    • Oct 2024
    Hello Zabbix Community,
    We are currently using Zabbix version 6.2.0 in our environment, and after running a security scan through Snyk, we discovered several vulnerabilities that we believe require attention and discussion. Here’s a summary of the findings:
    Critical Issues:
    • None identified
    High Severity:
    1. Server-side Request Forgery (SSRF)
      • CVE: CVE-2023-42282, CVE-2024-29415
      • CWE: CWE-918
      • Affected: package.json
      • Fixability: Fixable
      • POC Available
    2. Uncontrolled Resource Consumption
      • CVE: CVE-2024-4068
      • CWE: CWE-400
      • POC Available
    3. Prototype Pollution
      • CWE: CWE-1321
      • No known exploit currently available
    4. Inefficient Regular Expression Complexity
      • CVE: CVE-2024-4067
      • CWE: CWE-1333
    Medium Severity:
    1. Uncontrolled Resource Consumption ('Resource Exhaustion')
      • CVE: CVE-2024-28863
      • CWE: CWE-400
      • Fixability: Partially fixable
      • POC Available
    2. Missing Release of Resource after Effective Lifetime
      • CWE: CWE-772
      • POC Available
    We are currently staging an upgrade to a newer version of Zabbix and are curious whether these vulnerabilities will be resolved post-upgrade. Any insight or experiences regarding fixes in future releases would be helpful.
    I would appreciate the community’s input on the following:
    1. Are there any planned patches or updates in future Zabbix releases to address these vulnerabilities?
    2. Has anyone encountered or mitigated similar issues, particularly for SSRF and resource consumption vulnerabilities?
    3. Are there any temporary mitigation strategies for these vulnerabilities that we could implement while awaiting a fix?
    Looking forward to any advice or information the community can provide.
    Best regards,
    • 5004
    None of it looks like Zabbix bug, as long as I see... node.js and npm are not used... if you found them on your zabbix servers, you have put them there by your own will, they are not used by Zabbix (server written in C and frontend in php...)
    If you do not see that Zabbix IS affected, then you should not worry about theoretical issues...You can see all related stuff here https://www.zabbix.com/security_advisories and if you think you found something you can report it https://www.zabbix.com/zabbix_security_policy
