MSSQL by Zabbix agent 2 : mssql.cache_hit_ratio failed
  • studero
    • Aug 2023
    • 85
    Hi all,
    Configuration :
    Zabbix server version : 7.0.5 on RedHat
    Client Windows Server 2019
    Zabbix agent version : 7.0.4 with MSSQL plugins
    MSSQL version : 16
    The Item mssql.cache_hit_ratio return this following error :
    Preprocessing failed for: [{"object_name":"SQLServer:Plan Cache","cntr_value":3608,"counter_name":"Cache Hit Ratio","instan...
    1. Failed: cannot extract value from json by path "$[?(@.counter_name=='CacheHitRatio')].cntr_value.first()": no data matches the specified path
    And on the log server file :
    6326:20241024:101500.564 error reason for "svw-mssql-22p:mssql.cache_hit_ratio" changed: Preprocessing failed for: [{"object_name":"SQLServer:Plan Cache","cntr_value":3792,"counter_name":"Cache Hit Ratio","instan...
    1. Failed: cannot extract value from json by path "$[?(@.counter_name=='CacheHitRatio')].cntr_value.first()": no data matches the specified path​
    I need help to resolve this error.
    Regards
    Olivier
  • galavichid
    • Mar 2021
    • 45
    studero I have similar errors but on multiple items:
ID:	493386I have try manually to retrieve the metrics with SQL query:
    SELECT * FROM sys.dm_os_performance_counters WHERE instance_name = 'BOne';
    I got no results.
    So I have disable the AUTO_CLOSE option, then I got some of the counters with readings, but still nothing in Zabbix
    Error:
    Preprocessing failed for: [{"object_name":"MSSQL$SQLEXPRESSatabases","cntr_value":0,"counter_name":"State","i nstance_name...
    1. Failed: cannot extract value from json by path "$[?(@.counter_name=='Log Growths')].cntr_value.first()": no data matches the specified path​
    Do you get all the Logs values?
