Testing the LLD macro functions and I'm stuck with an wierd bug.
Rewrote the default linux OS template to the following, using the examples from https://www.zabbix.com/documentation...evel_discovery
Created a global macro thats says:
{$LOW_SPACE_LIMIT} = 20
Now if i create 1 host level macro everything is fine.
Lets say i create
{$LOW_SPACE_LIMIT:/home} = 99
(just to make it trigger)
And this works fine.
Problem arrises when i add more than one.
Lets add {$LOW_SPACE_LIMIT:/storage} = 90
Now the /storage trigger works, but the /home that was working is now suddenly using the default 20 limit.
It does the same in graph also.
If i remove macro for /storage it works as normal within seconds.
If i add a third macro for / it breaks both /home & /storage
This is using zabbix 3.2
Lets say i create
