Hi all,
We use Zabbix to receive SNMPv3 traps from other (management) systems.
These management systems can send SNMPv3 traps from 1500 different objects, which are defined in custom MIBs. We need to be able to forward these traps to other system using e-mail (SMTP).
As far as I can determine there is no way in Zabbix to forward a received SNMPv3 trap and pass object ID (OID, numeric value and/or symbolic value) and status (OctetString or Integer) using alert-script.
I expect it would be possible to read a value or pass a variable in the alert-script.
It is not possible to add all 1500 objects to zabbix manually. LLC SNMP OID discovery seems no option because all 1500 objects are unique.
I am not sure if this a bug, a requested feature or just lack of knowledge from my side.
Currently this is a blocking issue for our project. Please advice ASAP.
Kind regards,
Martin
Kind regards,
Martin
