icmpping not supported
  • sebasjuh
    • Sep 2016
    I installed zabbix version 3.2.3 on Ubuntu 16.0.4 LTS by this manual;
    click for manual
    And zabbix is working and I can access it by the browser.
    I created some triggers but the icmpping trigger doesn't work to warn me if a device is not reachable anymore.
    When I open the trigger from an added host the status of the trigger is Unknown. With a red exclamation mark and that says:
    Cannot evaluate expression: "Cannot evaluate function "servername:icmpping.max(#3)": item is not supported.".
    What am I missing why icmpping is not working?
  • kloczek
    • Jun 2006
    • 1771
    fping not installed?
    • sebasjuh
      • Sep 2016
      Fping was not installed so I thought that would be the problem.
      I installed fping on Ubuntu with the following command
      sudo apt-get install fping
      Restarted the server but I still got the same error.
      And when I enter the command
      fping (different serverip from my network)
      I get the answer servip is alive.
      So fping is working on my server.
      I even removed the # for the fping location in the zabbix-server.conf file but that doesn't resolve the problem either.
      • kloczek
        • Jun 2006
        • 1771
        You need to have look in into zabbix server/proxy logs to have look what is going on (pinger is part of the server/proxy and all ICMP probes are fired from those points).
        • sebasjuh
          • Sep 2016
          Thanks the error in server log was that fping couldn't be find.
          Problem was in zabbix server conf the fping folder was directed to /usr/sbin/fping and fping was installed in the location /usr/bin/fping.
          I changed it in the zabbis server conf en now everything is working fine!
          Thanks for your help.
