Websphere Application Server JMX monitoring error
  • ramondio
    • Nov 2024
    We are attempting to monitor Websphere Application Server, but we are getting the below error. We have the zabbix java gateway on the same location as the server. XX.XX.XXX.XX is the end server with WAS running on it.
    Unsupported or unrecognized SSL message: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/XX.XX.XX.XX:2070\/jmxrmi
    2024-11-21 10:58:11.939 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
    2024-11-21 10:58:11.939 [pool-2-thread-5] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://XX.XX.XXX.XX:2070/jmxrmi'
    2024-11-21 10:58:11.939 [pool-3-thread-1] TRACE c.z.g.ZabbixJMXConnectorFactory - making a call to JMXConnectorFactory.connect('service:jmx:rmi:///jndi/rmi://XX.XX.XXX.XX:2070/jmxrmi')
    2024-11-21 10:58:14.939 [pool-2-thread-5] TRACE c.z.g.ZabbixJMXConnectorFactory - no connector after 3 seconds
    2024-11-21 10:58:14.940 [pool-2-thread-5] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://XX.XX.XXX.XX:2070/jmxrmi'
    2024-11-21 10:58:14.940 [pool-3-thread-161] TRACE c.z.g.ZabbixJMXConnectorFactory - making a call to JMXConnectorFactory.connect('service:jmx:rmi:///jndi/rmi://XX.XX.XXX.XX:2070/jmxrmi')
    2024-11-21 10:58:14.962 [pool-3-thread-161] TRACE c.z.g.ZabbixJMXConnectorFactory - call to JMXConnectorFactory.connect('service:jmx:rmi:///jndi/rmi://XX.XX.XX.XX:2070/jmxrmi') timed out
    2024-11-21 10:58:14.962 [pool-2-thread-5] TRACE c.z.g.ZabbixJMXConnectorFactory - connector acquired
    2024-11-21 10:58:14.962 [pool-2-thread-5] WARN com.zabbix.gateway.SocketProcessor - error processing request, item "jmx["java.lang:type=Memory","NonHeapMemoryUsage.us ed"]
    " failed: Unsupported or unrecognized SSL message: service:jmx:rmi:///jndi/rmi://XX.XX.XX.XX:2070/jmxrmi
    2024-11-21 10:58:14.962 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
    com.zabbix.gateway.ZabbixException: Unsupported or unrecognized SSL message: service:jmx:rmi:///jndi/rmi://XX.XX.XX.XX:2070/jmxrmi
    at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:168)
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:76)
    at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1136)
    at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:635)
    at java.base/java.lang.Thread.run(Thread.java:840)
    2024-11-21 10:58:14.962 [pool-2-thread-5] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"Unsupported or unrecognized SSL message: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/XX.XX.XX.XX:2070\/jmxrmi"}
    2024-11-21 10:58:14.963 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
    2024-11-21 10:59:12.008 [pool-3-thread-1] TRACE c.z.g.ZabbixJMXConnectorFactory - call to JMXConnectorFactory.connect('service:jmx:rmi:///jndi/rmi://XX.XX.XX.XX:2070/jmxrmi') timed out
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 8 bytes of data length
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 233 bytes of request data
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG c.z.gateway.BinaryProtocolSpeaker - received the following data in request: {"request":"java gateway jmx","username":"USERNAME","password":"PASSWORD"," jmx_endpoint":"service:jmx:rmi:///jndi/rmi://XX.XX.XX.XX:2070/jmxrmi","keys":["jmx[\"java.lang:type=Compilation\",\"TotalCompilationTime\"]"]}
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG com.zabbix.gateway.SocketProcessor - RMI SSL hint cache cleanup is scheduled on 1732263049691, now is: 1732186754987
    2024-11-21 10:59:14.987 [pool-2-thread-1] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
    2024-11-21 11:00:20.064 [pool-2-thread-2] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"Unsupported or unrecognized SSL message: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/XX.XX.XX.XX:2070\/jmxrmi"}
    2024-11-21 11:00:20.064 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection zz0.ip06th5dpgqzz
    2024-11-21 11:00:20.064 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection zz0.rv6ha8k7jvzz
