Import error from 5.2.2 to 7.0.2
  • chg627
    • Jul 2024
    Hi all,
    I was trying to import templates from 5.2.2 to 7.0.2. it works well until the last step, when I click the import button, it showed an error like the image below. I tried google this error message but no useful guide was found. Anyone know how to fix it?
    Thanks in advance, Karl.
  • Answer selected by chg627 at 28-11-2024, 09:06.
    Julianna Wilamowska
    • Oct 2024
    • 34
    The error
    Invalid parameter "/51/host": invalid host name.
    is due to invalid characters in template name. Remove special characters (such as ( and )) and use the visible name field to use a name with special characters.
Name:	Screenshot 2024-11-27 123229.png
    • chg627
      chg627 commented
      Thanks a lot, that solve the problem.
      So the number "/51" represents template name? How do I find the parameters represented by the other numbers? Like "/1", "/2" or "/15"
  • Julianna Wilamowska
    • Oct 2024
    • 34
    The error
    • chg627
      chg627 commented
  • chg627
    • Jul 2024
    Ok, I got another number this time:
    Invalid parameter "/5/host"
    Special characters should be removed from all other Parameters not only Template name, is that so?
      • 4996
      Yes.
      /51 (or /5) does not represent template name, it is somehow related to which occurrence of "host" had issues.. I think.. like.. something like 5th use of host name or something.. I once tracked it in some reason, but dont remember any more..
