Template importing issue
  • ZabbMice
    • Sep 2024
    I have come up with an issue in uploading the template to Zabbix 7. It keeps saying "Graph ID 775 is not available". Screen shot attached.
    I am not sure what does this means?
    Thanks.
    Sasindu.
  • mrnobody
    • Oct 2024
    • 61
    Thanks.
    Sasindu.
    Hi Sasindu,
    Before import, open this template with an editor, i suggest Notepad ++, you'will see there is a typed language, that could be JSON, XML and YAML. This generate the template after imported. Find the string "775", you can comment the section lines (to test), or remove the Graph from template, deleting these lines. Also you can try to understand why Zabbix can't import those lines and generate what is necessary to create the "Grap ID 775", but this will require debug skills.
    Good Luck!
    • ZabbMice
      ZabbMice commented
      Hi mrnobody, Thanks for the reply. There is no Graph with ID 775. I have downloaded the default HP enterprise template from Zabbix 7 and re-uploading as a copy of it. By the way , I had created a tempalte for Aruba and they uploaded without any issues.
      The only string which has 775 in the entire template is a uuid containing that value. Which has no relationship to the Graph IDs.
  • markfree
    • Apr 2019
    • 875
    What template are you importing?
    • ZabbMice
      ZabbMice commented
      Hi Markfree,
      I have downloaded the default HP templates and changed the uuids and uploading again.
  • ZabbMice
    • Sep 2024
    Hi Markfree,
    This is the template I am trying to upload. It is not containing a Graph with id 775 ( as the error states). I wonder why zabbix expects a graph id 775 to be in the template.
    Can you please give a try to upload the attached template.
    Thanks.
    • Wojciech_Rawicki
      • Nov 2024
      Hi ZabbMice, have you tried to upload template without template dashboards? (Advanced options -> Template dashboards in Import template window)
