Zabbix upgrade from 6.4.4 to 7.0.6
  • bfarrell
    • Apr 2024
    When I try to update from version 6.4.4 to 7.0.6 I get the following:
    zabbix-agent is already the newest version (1:7.0.6-1+ubuntu20.04).
    zabbix-sql-scripts is already the newest version (1:7.0.6-1+ubuntu20.04).
    zabbix-release is already the newest version (1:7.0-2+ubuntu20.04).
    zabbix-apache-conf is already the newest version (1:6.4.4-1+ubuntu20.04).
    zabbix-frontend-php is already the newest version (1:6.4.4-1+ubuntu20.04).
    zabbix-server-mysql is already the newest version (1:6.4.4-1+ubuntu20.04).
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zabbix-proxy-mysql : Conflicts: zabbix-proxy-pgsql but 1:7.0.6-1+ubuntu20.04 is to be installed
    Conflicts: zabbix-proxy-sqlite3 but 1:7.0.6-1+ubuntu20.04 is to be installed
    zabbix-proxy-pgsql : Conflicts: zabbix-proxy-mysql but 1:7.0.6-1+ubuntu20.04 is to be installed
    zabbix-proxy-sqlite3 : Conflicts: zabbix-proxy-mysql but 1:7.0.6-1+ubuntu20.04 is to be installed
    zabbix-server-mysql : Conflicts: zabbix-server-pgsql but 1:4.0.17+dfsg-1 is to be installed
    zabbix-server-pgsql : Conflicts: zabbix-proxy-mysql but 1:7.0.6-1+ubuntu20.04 is to be installed
    Conflicts: zabbix-server-mysql but 1:6.4.4-1+ubuntu20.04 is to be installed
    E: Unable to correct problems, you have held broken packages.
    I've tried multiple guides to fix the problem but no luck. Any ideas? When I check version in the gui it says the version of zabbix agent is 7.0.6 but the server version is 6.4.4.
    • 5004
    Simple... your ubuntu 20.04 does not have server packages, as it is too old of a platform... use newer version of ubuntu..
