Agent2 stops responding
  • bjorn
    • Nov 2022
    Hello!
    Im having a problem where some of my windows agent2 stops responding.
    This has gotten worse lately with more and more servers suffering from this.
    I just upgraded from 5.2 to the latest version (both server and agents) but that didnt help, and the same servers are having the same problems.
    I put the logs in debug mode put dont see anything that seems weird to me, and nothing in common between the problem servers.
    If I try to restart the zabbix service, it will fail. I have to kill the process manually.
    Some of these servers barely have any software installed, one of them is a domain controller, its got nothing except the microsoft software, anti-virus and zabbix. Another is just a file server.
    I cant really see anything in common with these particular servers.
    This happens anywhere from 5 minutes to a week, but mostly within a couple days.
    Any ideas?
    Heres an example end of a log:
    2024/12/06 15:38:57.130611 plugin WindowsPerfMon: executing collector task
    2024/12/06 15:38:57.130611 plugin Cpu: executing collector task
    2024/12/06 15:38:57.549069 Calling C function "tls_new_server()"
    2024/12/06 15:38:57.549599 Calling C function "tls_free()"
    2024/12/06 15:38:57.549599 Calling C function "tls_ready()"
    2024/12/06 15:38:57.549599 Calling C function "tls_send()"
    2024/12/06 15:38:57.549599 Calling C function "tls_connected()"
    2024/12/06 15:38:57.549599 Calling C function "tls_accept()"
    2024/12/06 15:38:57.550153 Calling C function "tls_recv()"
    2024/12/06 15:38:57.550153 Calling C function "tls_send()"
    2024/12/06 15:38:57.550153 Calling C function "tls_accept()"
    2024/12/06 15:38:57.550689 Calling C function "tls_recv()"
    2024/12/06 15:38:57.551224 Calling C function "tls_recv()"
    2024/12/06 15:38:57.558134 Calling C function "tls_send()"
    2024/12/06 15:38:57.558134 Calling C function "tls_accept()"
    2024/12/06 15:38:57.558668 Calling C function "tls_recv()"
    2024/12/06 15:38:57.558668 Calling C function "tls_description()"
    2024/12/06 15:38:57.558668 Calling C function "free()"
    2024/12/06 15:38:57.559198 connection established using TLSv1.3 TLS_CHACHA20_POLY1305_SHA256
    2024/12/06 15:38:57.559198 Calling C function "free()"
    2024/12/06 15:38:57.559198 Calling C function "tls_connected()"
    2024/12/06 15:38:57.559198 Calling C function "tls_read()"
    2024/12/06 15:38:57.559704 Calling C function "tls_send()"
    2024/12/06 15:38:57.559780 Calling C function "tls_connected()"
    2024/12/06 15:38:57.559780 Calling C function "tls_read()"
    2024/12/06 15:38:57.559780 received passive check request: '{"request":"passive checks","data":[{"key":"service.info[\"NanoServiceMain\",state]","timeout":4}]}' from '192.168.200.17'
    2024/12/06 15:38:57.560311 [1] processing update request (1 requests)
    2024/12/06 15:38:57.560311 Calling C function "tls_new_server()"
    2024/12/06 15:38:57.560311 [1] adding new request for key: 'service.info["NanoServiceMain",state]'
    2024/12/06 15:38:57.560854 [1] created direct exporter task for plugin 'WindowsServices' itemid:0 key 'service.info["NanoServiceMain",state]'
    2024/12/06 15:38:57.560854 Calling C function "tls_free()"
    2024/12/06 15:38:57.560854 Calling C function "tls_ready()"
    2024/12/06 15:38:57.561387 Calling C function "tls_send()"
    2024/12/06 15:38:57.561387 Calling C function "tls_connected()"
    2024/12/06 15:38:57.561387 Calling C function "tls_accept()"
    2024/12/06 15:38:57.561387 Calling C function "tls_recv()"
    2024/12/06 15:38:57.561917 executing direct exporter task for key 'service.info["NanoServiceMain",state]'
    2024/12/06 15:38:57.561917 Calling C function "tls_send()"
    2024/12/06 15:38:57.561917 Calling C function "tls_accept()"
    2024/12/06 15:38:57.562442 executed direct exporter task for key 'service.info[[NanoServiceMain state]]'
    2024/12/06 15:38:57.562442 sending passive check response: '{"version":"7.0.6","variant":2,"data":[{"value":"0"}]}' to '192.168.200.17'
    2024/12/06 15:38:57.562442 Calling C function "tls_connected()"
    2024/12/06 15:38:57.562971 Calling C function "tls_write()"
    2024/12/06 15:38:57.562971 Calling C function "tls_recv()"
    2024/12/06 15:38:57.563501 Calling C function "tls_recv()"
    2024/12/06 15:38:57.563501 Calling C function "tls_close()"
    2024/12/06 15:38:57.564026 Calling C function "tls_recv()"
    2024/12/06 15:38:57.564571 Calling C function "tls_free()"
    2024/12/06 15:38:57.570618 Calling C function "tls_send()"
    2024/12/06 15:38:57.570618 Calling C function "tls_accept()"
    2024/12/06 15:38:57.571129 Calling C function "tls_recv()"
    2024/12/06 15:38:57.571154 Calling C function "tls_recv()"
    2024/12/06 15:38:57.571154 Calling C function "tls_description()"
    2024/12/06 15:38:57.571660 Calling C function "free()"
    2024/12/06 15:38:57.571850 connection established using TLSv1.3 TLS_CHACHA20_POLY1305_SHA256
    2024/12/06 15:38:57.571850 Calling C function "free()"
    2024/12/06 15:38:57.572362 Calling C function "tls_connected()"
    2024/12/06 15:38:57.572362 Calling C function "tls_read()"
    2024/12/06 15:38:57.572584 Calling C function "tls_send()"
    2024/12/06 15:38:57.572584 Calling C function "tls_connected()"
    2024/12/06 15:38:57.572584 Calling C function "tls_read()"
    2024/12/06 15:38:57.572584 received passive check request: '{"request":"passive checks","data":[{"key":"net.if.in[\"Nutanix VirtIO Ethernet Adapter\",errors]","timeout":4}]}' from '192.168.200.17'
    2024/12/06 15:38:57.573143 [1] processing update request (1 requests)
    2024/12/06 15:38:57.573143 [1] adding new request for key: 'net.if.in["Nutanix VirtIO Ethernet Adapter",errors]'
    2024/12/06 15:38:57.573143 [1] created direct exporter task for plugin 'NetIf' itemid:0 key 'net.if.in["Nutanix VirtIO Ethernet Adapter",errors]'
    2024/12/06 15:38:57.573659 executing direct exporter task for key 'net.if.in["Nutanix VirtIO Ethernet Adapter",errors]'
    2024/12/06 15:38:57.573693 Calling C function "tls_new_server()"
    2024/12/06 15:38:57.573693 Calling C function "tls_free()"
    2024/12/06 15:38:57.573693 Calling C function "tls_ready()"
    2024/12/06 15:38:57.574256 Calling C function "tls_send()"
    2024/12/06 15:38:57.574256 Calling C function "tls_connected()"
    2024/12/06 15:38:57.574256 Calling C function "tls_accept()"
    2024/12/06 15:38:57.574256 Calling C function "tls_recv()"
    2024/12/06 15:38:57.574784 executed direct exporter task for key 'net.if.in[[Nutanix VirtIO Ethernet Adapter errors]]'
    2024/12/06 15:38:57.574784 Calling C function "tls_send()"
    2024/12/06 15:38:57.574784 Calling C function "tls_accept()"
    2024/12/06 15:38:57.575294 sending passive check response: '{"version":"7.0.6","variant":2,"data":[{"value":"0"}]}' to '192.168.200.17'
    2024/12/06 15:38:57.575294 Calling C function "tls_connected()"
    2024/12/06 15:38:57.575606 Calling C function "tls_write()"
    2024/12/06 15:38:57.575606 Calling C function "tls_recv()"
    2024/12/06 15:38:57.576118 Calling C function "tls_recv()"
    2024/12/06 15:38:57.576161 Calling C function "tls_recv()"
    2024/12/06 15:38:57.576161 Calling C function "tls_close()"
    2024/12/06 15:38:57.576705 Calling C function "tls_recv()"
    2024/12/06 15:38:57.576705 Calling C function "tls_free()"
    2024/12/06 15:38:57.577958 Calling C function "tls_send()"
    2024/12/06 15:38:57.577958 Calling C function "tls_accept()"
    2024/12/06 15:38:57.578657 Calling C function "tls_recv()"
    2024/12/06 15:38:57.579221 Calling C function "tls_description()"
    2024/12/06 15:38:57.579221 Calling C function "free()"
    2024/12/06 15:38:57.579221 connection established using TLSv1.3 TLS_CHACHA20_POLY1305_SHA256
    2024/12/06 15:38:57.579754 Calling C function "tls_connected()"
    2024/12/06 15:38:57.579754 Calling C function "tls_read()"
    2024/12/06 15:38:57.579754 Calling C function "tls_send()"
    2024/12/06 15:38:57.580289 received passive check request: '{"request":"passive checks","data":[{"key":"system.uptime","timeout":4}]}' from '192.168.200.17'
    2024/12/06 15:38:57.580289 [1] processing update request (1 requests)
    2024/12/06 15:38:57.580797 [1] adding new request for key: 'system.uptime'
    2024/12/06 15:38:57.580836 [1] created direct exporter task for plugin 'Uptime' itemid:0 key 'system.uptime'
    2024/12/06 15:38:57.580836 executing direct exporter task for key 'system.uptime'
    2024/12/06 15:38:57.583514 executed direct exporter task for key 'system.uptime[[]]'
    2024/12/06 15:38:57.583514 sending passive check response: '{"version":"7.0.6","variant":2,"data":[{"value":"1684665"}]}' to '192.168.200.17'
    2024/12/06 15:38:57.584045 Calling C function "tls_connected()"
    2024/12/06 15:38:57.584045 Calling C function "tls_write()"
    2024/12/06 15:38:57.584045 Calling C function "tls_recv()"
    2024/12/06 15:38:57.584553 Calling C function "tls_recv()"
    2024/12/06 15:38:57.584583 Calling C function "tls_close()"
    2024/12/06 15:38:57.584583 Calling C function "tls_recv()"
    2024/12/06 15:38:57.585119 Calling C function "tls_free()"
    2024/12/06 15:38:58.131688 plugin WindowsPerfMon: executing collector task
    2024/12/06 15:38:58.132247 plugin Cpu: executing collector task
    2024/12/06 15:38:58.549424 Calling C function "tls_new_server()"
    2024/12/06 15:38:58.549958 Calling C function "tls_free()"
    2024/12/06 15:38:58.549958 Calling C function "tls_ready()"
    2024/12/06 15:38:58.549958 Calling C function "tls_send()"
    2024/12/06 15:38:58.549958 Calling C function "tls_connected()"
    2024/12/06 15:38:58.549958 Calling C function "tls_accept()"
    2024/12/06 15:38:58.550489 Calling C function "tls_recv()"
    2024/12/06 15:38:58.550489 Calling C function "tls_send()"
    2024/12/06 15:38:58.550489 Calling C function "tls_accept()"
    2024/12/06 15:38:58.551024 Calling C function "tls_recv()"
    2024/12/06 15:38:58.551604 Calling C function "tls_recv()"
    2024/12/06 15:38:58.563335 Calling C function "tls_send()"
    2024/12/06 15:38:58.563335 Calling C function "tls_accept()"
    2024/12/06 15:38:58.563895 Calling C function "tls_recv()"
    2024/12/06 15:38:58.564445 Calling C function "tls_recv()"
    2024/12/06 15:38:58.564445 Calling C function "tls_description()"
    2024/12/06 15:38:58.564445 Calling C function "free()"
    2024/12/06 15:38:58.564961 connection established using TLSv1.3 TLS_CHACHA20_POLY1305_SHA256
    2024/12/06 15:38:58.564997 Calling C function "free()"
    2024/12/06 15:38:58.564997 Calling C function "tls_connected()"
    2024/12/06 15:38:58.564997 Calling C function "tls_read()"
    2024/12/06 15:38:58.565556 Calling C function "tls_send()"
    2024/12/06 15:38:58.565556 Calling C function "tls_connected()"
    2024/12/06 15:38:58.565556 Calling C function "tls_read()"
    2024/12/06 15:38:58.565556 received passive check request: '{"request":"passive checks","data":[{"key":"service.info[\"PSUAService\",state]","timeout":4}]}' from '192.168.200.17'
    2024/12/06 15:38:58.566115 [1] processing update request (1 requests)
    2024/12/06 15:38:58.566115 [1] adding new request for key: 'service.info["PSUAService",state]'
    2024/12/06 15:38:58.566115 [1] created direct exporter task for plugin 'WindowsServices' itemid:0 key 'service.info["PSUAService",state]'
    2024/12/06 15:38:58.566115 Calling C function "tls_new_server()"
    2024/12/06 15:38:58.566658 executing direct exporter task for key 'service.info["PSUAService",state]'
    2024/12/06 15:38:58.566658 Calling C function "tls_free()"
    2024/12/06 15:38:58.566658 Calling C function "tls_ready()"
    2024/12/06 15:38:58.567171 Calling C function "tls_send()"
    2024/12/06 15:38:58.567208 Calling C function "tls_connected()"
    2024/12/06 15:38:58.567208 Calling C function "tls_accept()"
    2024/12/06 15:38:58.567208 Calling C function "tls_recv()"
    2024/12/06 15:38:58.567208 executed direct exporter task for key 'service.info[[PSUAService state]]'
    2024/12/06 15:38:58.567748 Calling C function "tls_send()"
    2024/12/06 15:38:58.567748 Calling C function "tls_accept()"
    2024/12/06 15:38:58.567748 sending passive check response: '{"version":"7.0.6","variant":2,"data":[{"value":"0"}]}' to '192.168.200.17'
    2024/12/06 15:38:58.567748 Calling C function "tls_connected()"
    2024/12/06 15:38:58.568292 Calling C function "tls_write()"
    2024/12/06 15:38:58.568292 Calling C function "tls_recv()"
    2024/12/06 15:38:58.568837 Calling C function "tls_recv()"
    2024/12/06 15:38:58.568837 Calling C function "tls_close()"
    2024/12/06 15:38:58.569381 Calling C function "tls_recv()"
    2024/12/06 15:38:58.569381 Calling C function "tls_free()"
    2024/12/06 15:38:58.575581 Calling C function "tls_send()"
    2024/12/06 15:38:58.576149 Calling C function "tls_accept()"
    2024/12/06 15:38:58.576149 Calling C function "tls_recv()"
    2024/12/06 15:38:58.576705 Calling C function "tls_recv()"
    2024/12/06 15:38:58.576705 Calling C function "tls_description()"
    2024/12/06 15:38:58.576705 Calling C function "free()"
    2024/12/06 15:38:58.577389 connection established using TLSv1.3 TLS_CHACHA20_POLY1305_SHA256
    2024/12/06 15:38:58.577389 Calling C function "free()"
    2024/12/06 15:38:58.577901 Calling C function "free()"
    2024/12/06 15:38:58.578142 Calling C function "tls_connected()"
    2024/12/06 15:38:58.578142 Calling C function "tls_read()"
    2024/12/06 15:38:58.578142 Calling C function "tls_send()"
    2024/12/06 15:38:58.578711 Calling C function "tls_connected()"
    2024/12/06 15:38:58.578711 Calling C function "tls_read()"
    2024/12/06 15:38:58.578711 received passive check request: '{"request":"passive checks","data":[{"key":"net.if.in[\"Nutanix VirtIO Ethernet Adapter\"]","timeout":4}]}' from '192.168.200.17'
    2024/12/06 15:38:58.579319 [1] processing update request (1 requests)
    2024/12/06 15:38:58.579319 [1] adding new request for key: 'net.if.in["Nutanix VirtIO Ethernet Adapter"]'
    2024/12/06 15:38:58.579319 [1] created direct exporter task for plugin 'NetIf' itemid:0 key 'net.if.in["Nutanix VirtIO Ethernet Adapter"]'
    2024/12/06 15:38:58.579874 executing direct exporter task for key 'net.if.in["Nutanix VirtIO Ethernet Adapter"]'
    2024/12/06 15:38:58.580414 executed direct exporter task for key 'net.if.in[[Nutanix VirtIO Ethernet Adapter]]'
    2024/12/06 15:38:58.580414 sending passive check response: '{"version":"7.0.6","variant":2,"data":[{"value":"1691513257"}]}' to '192.168.200.17'
    2024/12/06 15:38:58.580414 Calling C function "tls_connected()"
    2024/12/06 15:38:58.580998 Calling C function "tls_write()"
    2024/12/06 15:38:58.580998 Calling C function "tls_recv()"
    2024/12/06 15:38:58.581563 Calling C function "tls_recv()"
    2024/12/06 15:38:58.581563 Calling C function "tls_close()"
    2024/12/06 15:38:58.582118 Calling C function "tls_recv()"
    2024/12/06 15:38:58.582628 Calling C function "tls_free()"
