Zabbix Docker image 7.07 Bug with launch
  • devops86
    • Jul 2024
    Zabbix Docker image 7.07 Bug with launch: zabbix-server-pgsql:ubuntu-7.0-latest has a bug can anybody confirm it, container just won't start, keeps loop restarting, 7.06 has no problems at all.
    Possible same thing with proxy sqlite container, but has not tested it, Frontend works, same with agent etc. Aborted entire upgrade process, reverted back from pipeline
    using Roky 9.5 env
    Problem is with this: /usr/sbin/zabbix_server: error while loading shared libraries: libevent_extra-2.1.so.7: cannot open shared object file: No such file or directory.
    Kristjan
  • PavelZ
    • Dec 2024
    • 171
    There are reported to be several issues with this version - https://support.zabbix.com/browse/ZBX-25765
    • devops86
      • Jul 2024
      7.08v They fixed it, problem solved
