unable to create graphs in template
  • tlacroix
    • Dec 2013
    • 30
    Hi there,
    I've created a template where i've defined an item (an IPMI check -- text), and a trigger for that item.
    The template works perfectly, the item is retrived, and the trigger also works
    I'm not able to create a graph for that templated item, when I click on "Add" button, "No data found".
    Same problem if I want to manually create a graph for an host where this template is.
    Any tip ?
    Thanks!
    -- Zabbix 3.2.3
  • batchenr
    • Sep 2016
    • 440
    Originally posted by tlacroix
    Hi there,
    Any tip ?
    -- Zabbix 3.2.3
    try to create the graph at Template itself
    if it does not work then please post screen shots
    Thanks!
    • tlacroix
      • Dec 2013
      • 30
      Thank you for your reply
      I've tried to create the graph at template level itself, same result
      Please, see screens,
      Vous avez des images? Envoyez-les et partagez-les super rapidement avec NoelShack!
      Thank you
      • batchenr
        • Sep 2016
        • 440
        Thank you
        mmm..
        cpuld it be that the type of imfo is text ? can you change it to numeric ?
        • tlacroix
          • Dec 2013
          • 30
          yep it is.
          changed from text to numeric float, and now i have something to add in template > graph > create graph > "add"
          weird behaviour, anyway thank you!
          • batchenr
            • Sep 2016
            • 440
            yep it is.
            i guess that Graphs can only show numeric values so thats why
            it was painted grey.
            glad it helps
