GCP: Authorization has failed
  • mickael
    • Mar 2022
    Dear All,
    I'm using Google Cloud (GCP) Template for Zabbix since a while now.
    Unfortunalty, since few days, the Template failed to get data from GCP, this is the same issue for all our GCP Project :
    - GCP: Authorization has failed
    - Preprocessing failed for: {"error":{}} : Failed: Request had invalid authentication credentials. Expected OAuth 2 access token, login cookie or other valid authentication credential.
    On GCP side, the service account is still valid and the permission are set the Projet Viewer. I tried to create a new service account key, but the error is still present.
    I also try to upgrade to the last GCP Template, but the issue is still present.
    Our Zabbix version is 7.0.7
    I'm running out of idea now.
    Thanks a lot for your help.
    Mickaël
  • AlexeySaff
    • Aug 2021
    • 22
    I've had exactly the same issue, and my idea was that this was due to an update from 7.2 to 7.2.1, but seems a reply from Zabbix was changed. I tried to update template from 7.0 to 7.0-1, but I had no luck
    Would be great if someone can point what's the issue here
    • AlexeySaff
      • Aug 2021
      • 22
      It seems like a reply was changed on GCP side as previously we had just empty string and now {} where trigger is checking length of the error code
      • AlexeySaff
        • Aug 2021
        • 22
        so I bet it comes after 7.0.7 update for you and 7.2.1 for me. and the problem here is the authorization preprocessing $.error and next check where previously zabbix returned empty string and now {}
        so the stupid and quick fix is to change the trigger from
        length(last(/GCP by HTTP/gcp.auth.err.check)) > 0
        to
        last(/GCP by HTTP/gcp.auth.err.check) <> "{}"
        but after that, we have more problems in getting states of the machines. Investigating
        • AlexeySaff
          • Aug 2021
          • 22
          no, sorry, my bad. but something is broken in 7.2.1 for sure as when I test item it returns back proper auth token, but from the zabbix execution it returns
          {"error":{}}
          for auth
          • AlexeySaff
            • Aug 2021
            • 22
            I'm out of ideas..... trst of the item returns valid token, zabbix_js returns valid token, but in zabbix execution it returns
            {"error":{}}
            this comes from that part of the code
            try {
            jwt = encodeJWT(headers, payload, script_params.private_key);
            token = exchangeJwtForAccessToken(jwt);
            return token;
            catch (err) {
            return JSON.stringify({ error: err });
            • AlexeySaff
              • Aug 2021
              • 22
              Cannot execute script: Error: failed to import private key
              at [anon] (global.c:381) internal
              at [anon] () native strict preventsyield
              at encodeJWT (function:30)
              at [anon] (function:104) preventsyield
              so the problem is with importing private key. so that is definitely something with the zabbix update
              • AlexeySaff
                • Aug 2021
                • 22
                you need to delete all escape n from your private key. works for me now . not sure what was changes in checking escaping in java code
                • ServicesIt
                  ServicesIt commented
                  Thank you, this worked for me. (Zabbix LTS 7.0)
              • mickael
                • Mar 2022
                Thanks a lot Alexey, after removing the escape n, it work again.
                • doppler
                  • Jan 2025
                  Thank you all for this thread. I had 4 zabbix instances monitoring 4 gcp enivronments with this exact problem, now all fixed thanks to this thread!
