Memory usage percent item prototype on proxmox ve http template
  • asnrainbow
    • Dec 2024
    I've started to use the template to monitor my proxmox servers and its great except that i dont get RAM usage % just like CPU usage %
    So i tried to make a new item prototype for the node item prototypes and its been unsuccessful so far
    Im on Zabbix 7.0.6
    my latest attempt looks like this:
    I cloned the CPU prototype and modified it to look like this:
    Name: Node [{#NODE.NAME}]: Memory, usage percent
    Type: Calculated
    Key: proxmox.node.memory.percent[{#NODE.NAME}]
    Formula: last(/Proxmox VE by HTTP/proxmox.node.memused[{#NODE.NAME}]) / last(/Proxmox VE by HTTP/proxmox.node.memtotal[{#NODE.NAME}]) * 100
    Units : %
    Update Interval: 60s
    Tags:
    inherited:
    class software
    target proxmox
    new:
    Component Value memory
    node {#NODE.NAME}
    No Preprocessing
    Im ending up with this error on latest data check: "Cannot evaluate function: item "/Proxmox VE by HTTP/proxmox.node.memused[pve]" does not exist at "last(/Proxmox VE by HTTP/proxmox.node.memused[pve]) / last(/Proxmox VE by HTTP/proxmox.node.memtotal[pve]) * 100"."
    It seems i cant find the values im looking for and i don't know which path i should put in
    Thank you if you take time to try and help me
  • asnrainbow
    • Dec 2024
    ok i solved the issue changing the formula to this:
    100 * last(//proxmox.node.memused[{#NODE.NAME}]) / last(//proxmox.node.memtotal[{#NODE.NAME}])
