Unable to login 1.1.4
  • Rory Slegtenhorst
    SuSE 10.1, Apache 2.2.0, PHP 5.1.2, MySQL 5.0.18, Zabbix 1.1.4
    Executed so far:
    cd /usr/src
    tar -xzf zabbix-1.1.4.tar.gz
    cd zabbix-1.1.4
    ./configure --prefix=/opt/zabbix --enable-server --enable-agent --with-mysql --with-net-snmp
    make
    make install
    mkdir /srv/www/htdocs/zabbix
    cp -r frontend/php/* /srv/www/htdocs/zabbix/
    mkdir /etc/zabbix
    cp misc/conf/zabbix_agentd.conf /etc/zabbix
    cp misc/conf/zabbix_server.conf /etc/zabbix
    cp misc/init.d/suse/9.3/zabbix_agentd /etc/init.d
    cp misc/init.d/suse/9.3/zabbix_server /etc/init.d
    cat create/mysql/schema.sql|mysql -u root -p zabbix
    cat create/data/data.sql|mysql -u root -p zabbix
    cat create/data/images.sql|mysql -u root -p zabbix
    groupadd -g 555 zabbix
    useradd -d /opt/zabbix -G zabbix -g zabbix -u 555 -s /bin/bash zabbix
    I modified /srv/www/htdocs/zabbix/include/db.inc.php with the following:
    $DB_TYPE = "MYSQL";
    $DB_SERVER = "localhost";
    $DB_DATABASE = "zabbix";
    $DB_USER = "zabbix";
    $DB_PASSWORD = "zabbix";
    I also modified the configuration/start-stop scripts to follow my installation paths.
    Problem:
    I am unable to login the frontend using Admin as username.
    Yes I have kept the password blank.
    I also have changed the password using phpMyAdmin to add MD5(password), but this doesn't help either.
    No logging from any of my services involved to show any errors...
    Is there an incompatibility I'm unaware of?
    [B]Update:[B]
    I ran dos2unix on most of the files that are in the source...
    Thanks for any help,
    Rory Slegtenhorst
  • Rory Slegtenhorst
    RE: Unable to login 1.1.4
    Hi again,
    My apologies for this one...
    It happens to be that the time on my client was set to 27 jan 2007...
    Obviously this was the cause of all my troubles...
    Thanks again,
    Rory Slegtenhorst
