Zabbix Web Service error
  • joel.john
    • Jan 2025
    I'm facing trouble enabling the schedule report services. I've tried most of the recommendations in the forum but still does not work.
    The error:
    Test log
    2025/01/02 16:10:43.969960 http: TLS handshake error from 192.168.10.45:60708: tls: client didn't provide a certificate
    Here are some of the settings: /etc/zabbix/zabbix_web_service.conf
    AllowedIP=0.0.0.0/0
    TLSAccept=cert
    TLSCAFile=/etc/ssl/certs/fullchain.pem
    TLSCertFile=/etc/ssl/certs/fullchain.pem
    TLSKeyFile=/etc/pki/tls/private/privkey.pem
    IgnoreURLCertErrors=1
    Zabbix Web Service Status
    ● zabbix-web-service.service - Zabbix Web Service
    Loaded: loaded (/usr/lib/systemd/system/zabbix-web-service.service; enabled; vendor preset: disabled)
    Active: active (running) since Thu 2025-01-02 15:53:53 UTC; 26min ago
    Process: 587900 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=0/SUCCESS)
    Main PID: 587902 (zabbix_web_serv)​
    Nginx Settings /etc/nginx/conf.d/zabbix.conf #This sites redirect port 80 to use ssl and works. Using the same Certs.
    server {
    listen 80;
    server_name zabbix.renamed.com;
    return 301 https://$host$request_uri;
    server {
    listen 443 ssl http2;
    root /usr/share/zabbix;
    index index.php;
    ssl_certificate "/etc/ssl/certs/fullchain.pem";
    ssl_certificate_key "/etc/pki/tls/private/privkey.pem";
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_verify_client off; # This requires clients to present a valid certificate
    location = /favicon.ico {
    log_not_found off;
    CERT Test
    curl -v --cacert /etc/ssl/certs/fullchain.pem "https://zabbix.renamed.com:10053/report"
    Related /etc/zabbix/zabbix_server.conf configuration
    # Default:
    StartReportWriters=1
    WebServiceURL=https://zabbix.mired.com.do:10053/report​​
    FrontEnd Parameters
    Permisions
    The user zabbix can access and read the content of the cert file.
    [root@appliance ~]# sudo -u zabbix cat /etc/ssl/certs/fullchain.pem
    -----BEGIN CERTIFICATE-----
    Don't know what else to test. Can you guide me please?​​
