MS SQL query
  • RedHappy
    • Mar 2017
    MS SQL query
    Hi. I make connection to ms sql. Then have created a new odbc sql query that makes a select on the Sql. If there is no lock, the table is empty and everything is fine. If the table is not empty, something in the database made a lock and should be triggered by zabbix.
    I run query in console
    SQL> select *MYSELECT*
    | CriticalityLevel|
    SQLRowCount returns 0
    But in trigger i see: SQL query returned empty result. Zabbix ver. 3.2
    Please, help me
  • batchenr
    • Sep 2016
    • 440
    | CriticalityLevel|
    Please, help me
    please post your trigger here.
    and i think you can use zabbix_get for this - like run a remote command
    system.run[the command that you run]
    and in the trigger u should set if no data then...
    • RedHappy
      • Mar 2017
      Here.
      Thank you
      • batchenr
        • Sep 2016
        • 440
        Here.
        Thank you
        can u try to change type of information to char
        and make a trigger with the exprestion nodata()<5m or close
        • RedHappy
          • Mar 2017
          After i changed type
          • Atsushi
            • Aug 2013
            • 2028
            How about getting SQL results with count (*)?
            If there is no corresponding record, I think that you can get a value of 0.
            • RedHappy
              • Mar 2017
              from MS SQL management studio
              select CriticalityLevel from dbo.[*********] where ClassNum = 52154
              No data
              select * from dbo.[*******]
              ClassNum CriticalityLevel
              52184 0
              Because all fine.
