Problem with triggers prototypes
  • dmn653
    • Jan 2025
    Hello everyone,
    Have a new installation of Zabbix 7.0 on MariaDB 11. I have configured VMware template to autodiscovery my ESXi environment, seems like all works fine except one thing.
    In template VM Guest triggers prototypes for low disk space and critical disk space are work only on *unix systems. For all discovered Windows machines triggers from prototypes doesn't created. All data related to FS discovery from item prototypes are available in monitoring for each host in % and bytes.
    Tried to clone template and recreate items discovery and triggers prototypes, but with same result. What I'm doing wrong? How to start Zabbix create triggers from prototypes for VM with Windows Servers guest OS?
    Have an Windows Server 2019/2022 and FS ntfs/ReFS.
  • ismail.atmaca
    • Jan 2025
    We have a similar problem, does anyone have any ideas? At what stage could there be a deficiency? While Linux VMs create disk space triggers and reports, Windows VMs do not create disk space triggers.
    • ismail.atmaca
      • Jan 2025
      I think the solution link is.
      Same error with 7.0.5.
      I found if I wrapped {FSNAME} in single quotes first, '{FSNAME}' then wrapped back in double quotes "'{#FSNAME}'" it worked as intended and I have my guest volumes reporting.
      Code:max(/VMware Guest/vmware.vm.vfs.fs.size[{$VMWARE.URL},{$VMWARE.VM.UUID},{#FSNAME},pfree],5m)<{$VMWARE.VM.FS.PFREE.MIN.CRIT:"'{#FSNAME}'"} and {$VMWARE.VM.FS.TRIGGER.USED:"'{#FSNAME}'"}=1
      • dmn653
        • Jan 2025
        Thx a lot. It works.
