[ZABBIX] Seamless Integration Series - Episode 5: DFRobot SEN0438
  • tiago.guimaraes
    • Apr 2024
    • 17
    Hello, Zabbix community!
    The fifth episode of the [ZABBIX] Seamless Integration Series is now live. In this episode, we focus on integrating the DFRobot SEN0438, a high-precision temperature and humidity sensor, into Zabbix for real-time environmental monitoring.
    Key Highlights:
    • Track temperature and humidity with Modbus RTU/TCP.
    • Set up triggers for abnormal conditions to maintain optimal environments.
    • Build dashboards for clear and consolidated environmental insights.
    Link to the full post: https://www.linkedin.com/pulse/zabbi...3%25A3es-ehbcf
    This episode provides a macro-level overview of integrating the SEN0438, ideal for IoT applications like server rooms, greenhouses, and laboratories.
    Check it out, and let us know your experiences and tips for working with environmental sensors in Zabbix!
  • markfree
    • Apr 2019
    • 875
    How about posting this series of posts in the Zabbix Cookbook subforum?
    It is meant for you to
    Share your experience about monitoring of specific applications, devices, network equipment with ZABBIX.
