Can't disable trigger on host level
  • AlexeySaff
    • Aug 2021
    • 22
    I think starting from 7.2.1 and 7.2.2 (not sure tbh), I can't disable the trigger anymore on the host level. So let's say we have something discovered on the host from the main template, but on particular host I don't want to have specific trigger. So previously I just selected alarm and untick "enabled" on the trigger. Now in tickbox I untick and click "save" trigger and alarm is still in the list and when I go to config again tickbox is selected
  • cptneko
    • Jun 2024
    7.2.1 is definitely affected, we have noticed it too this morning. Now I upgraded to 7.2.2 in hopes of it being fixed, but still an issue for us.
      • 4996
      Have you checked, is there already a bug report on the topic? https://support.zabbix.com/projects/ZBX/
      If not, maybe you can submit one.
      • thomas598brown
        • Jan 2025
        Hello AlexeySaff ,
        Starting from Zabbix versions 7.2.1 and 7.2.2, disabling a trigger on the host level seems to be a known issue. While previously you could simply untick "enabled" to disable a specific trigger, it no longer works consistently1. This may be something the developers are working to address, so keep an eye out for updates.
        Best Regards,
        Thomas Brown
        • thomas598brown
          • Jan 2025
          Originally posted by thomas598brown
          Hello AlexeySaff ,
          Starting from Zabbix versions 7.2.1 and 7.2.2, disabling a trigger on the host level seems to be a known issue. While previously you could simply untick "enabled" to disable a specific trigger, it no longer works consistently. This may be something the developers are working to address, so keep an eye out for updates. WhataburgerVisit com
          Best Regards,
          Thomas Brown
          Thank You for support
          • AlexeySaff
            • Aug 2021
            • 22
            I hope that's just a temp bug and will be fixed soon. otherwise it's terrible
            • AlexeySaff
              • Aug 2021
              • 22
              https://support.zabbix.com/browse/ZBX-25857 - fingers crossed
              • taken
                • May 2015
                • 15
                They just release new 7.0.9 and problem still exist...
                • AlexeySaff
                  • Aug 2021
                  • 22
                  7.2.3 still the same
                  • AlexeySaff
                    • Aug 2021
                    • 22
                    trigger can be disabled from the list of trigger on the host and not popup window
                    • AlexeySaff
                      • Aug 2021
                      • 22
                      7.2.4 - fixed
