regexp with parenthesis
  • wuhaohust
    • Jan 2025
    • 10
    I am running zabbix 7.0.5 on SUSE15, I want to create a trigger for snmptrap which contains "Network Time Protocol(NTP) is not configured" , trap received by zabbix is like below:
    2025-01-12T21:20:42+0800 PDU INFO:
    notificationtype TRAP
    securityEngineID 0x80001370017f0000016ebd0bed
    securityName xxxxxx
    transactionid 1668
    errorindex 0
    receivedfrom UDP: [xxxxxx]:161->[xxxxx]:162
    messageid 107453
    securitylevel 3
    errorstatus 0
    contextEngineID 0x80001370017f0000016ebd0bed
    contextName
    requestid 1450683266
    version 3
    securitymodel 3
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (1894589500) 219 days, 6:44:55.00
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.11.2.36.1.0.5
    SNMPv2-SMI::enterprises.11.2.36.1.1.5.1.1.1.1 type=2 value=INTEGER: 1
    SNMPv2-SMI::enterprises.11.2.36.1.1.5.1.1.4.1 type=6 value=OID: SNMPv2-SMI::enterprises.11.10.3.1.3.27
    SNMPv2-SMI::enterprises.11.2.36.1.1.5.1.1.2.1 type=4 value=STRING: "HPE StoreOnce 3660 SGH418F5P8"
    SNMPv2-SMI::enterprises.11.2.36.1.1.5.1.1.5.1 type=4 value=STRING: "https://172.25.1.32"
    SNMPv2-SMI::enterprises.11.2.36.1.1.5.1.1.6.1 type=4 value=STRING: "HPE StoreOnce 3660 SGH418F5P8"
    SNMPv2-SMI::enterprises.11.2.36.1.0.10 type=4 value=STRING: "E033C000013"
    SNMPv2-SMI::enterprises.11.2.36.1.0.11 type=4 value=STRING: "Network Time Protocol(NTP) is not configured. This might cause issues with features like Active Directory, LDAP or Two-Factor Authentication. "
    • find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol(NTP) is not configured")=1 --- this one doesn't work
    • find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol\(NTP\) is not configured")=1 --- tried to escape the parenthesis, but failed with error message : Invalid parameter "/1/expression": incorrect expression starting from "find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol\(NTP\) is not configured")=1".
    • find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol.* is not configured")=1 ---- working
    • find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol")=1 ---- if simply use "Network Time Protocol" to match , working
    Can someone guide me how can match "Network Time Protocol(NTP) is not configured" in zabbix ?
  • Answer selected by wuhaohust at 23-01-2025, 03:39.
    Hamardaban
    • May 2019
    • 2714
    find(/snmp trap template/snmptrap.fallback,,"regexp","Network Time Protocol\\(NTP\\) is not configured")=1
    worked for me... v7.2 Zabbix
    • wuhaohust
      wuhaohust commented
      works for V7.0.5
  • kyus
    • Feb 2024
    • 204
    Hey!
    Have you tried using the operator "like" instead of "regexp"?
    From the docs:
    like (default for string, text, log) - matches if contains the string given in pattern (case-sensitive)
    • wuhaohust
      wuhaohust commented
      Hi jyus,
      Thanks for your comment. "like" operator works, but I will want to know how can we escape parenthesis with regexp , do you have any idea or experience ?
  • kyus
    • Feb 2024
    • 204
    Well, i did use regex in Zabbix, but never with the find function, i will link some docs with info about regex and escaping characters, hope it helps!
      • 4996
      worked just fine for me... v6 Zabbix
      • wuhaohust
        wuhaohust commented
        hmm, this expression is invalid in my env 7.0.5
    • Hamardaban
      • May 2019
      • 2714
      • wuhaohust
        wuhaohust commented
        works for V7.0.5
    • kyus
      • Feb 2024
      • 204
      Only worked in v6 for me.
      Worked in v6, v7 and v7.2...
