Aruba Switch 6100
  • muciw
    • Jan 2025
    Aruba Switch 6100
    I would like to ask a question and hopefully get an answer here.
    Whenever I add SNMP v2 to an Aruba 6100/6100F switch, it always shows a red SNMP indicator and fails consistently.
    I’m confident that my SNMP v2 configuration on the switch is correct.
    Has anyone encountered the same issue?
    Thank you,
    Adam
    Zabbix Version 7.2
    Ubuntu 24.04 Click image for larger version
Name:	Screenshot 2025-01-21 145811.png
  • furkansenyuva
    • Feb 2025
    Hello, Muciw,
    I also use Aruba 6100 devices at my workplace, and I was experiencing the same issue. Today, I came across the post you shared, and knowing that I’m not alone motivated me to dig deeper into solving the problem. After some experimenting, I managed to resolve it.
    Briefly, here’s what you need to do: Connect to one of the Aruba 6100 devices using Putty and execute the following commands in the CLI. But before that, I kindly ask you to check the SNMP panel in the Aruba device’s interface to see if there is a user named "Public."
    Commands:
    1. conf ter
    2. snmp-server trap-source <Zabbix_Ip_Address>
    3. snmp-server vrf default
