Notification message trucated
  • andresf
    • Jan 2017
    • 16
    Hello
    Using version 3.2 in ubuntu server 14.04
    I´m having a problem with notification message content. Te message is truncated, but not truncated at a specific length. Sometimes is truncated randomly. In the table "events" the message is inserted truncated and the same appers in zabbix log file.
    Wih this message template
    Recuperado
    {EVENT.ID}
    Fecha y hora: {EVENT.DATE} {EVENT.TIME}
    I've got
    Recuperado
    8749
    Fecha y hora: 2017.03.22 09:26
    It missing the "seconds" part.
    With a larger message template (including a large number of macros) it is truncated much further than the previous message
    EDIT:
    This is not happens with Ubuntu Desktop 14.04
    Any help?
    thanks in advance
  • andresf
    • Jan 2017
    • 16
    Solved (Workaround)
    Workaround at https://www.zabbix.com/forum/showpos...43&postcount=9
    • akelio
      • Mar 2016
      • 9
      Originally posted by andresf
      Hey, thanks for workaround. I got the same issue after upgrading to 3.0.8
      Have you seen related bugs on support.zabbix.com?
      Just to keep an eye on it
      Oh...found it https://support.zabbix.com/browse/ZBX-11855
      • andresf
        • Jan 2017
        • 16
        Hi. I knew of that fix, but i can't upgrade right now.
        Have you tried on Ubuntu Server 14.04?
        • akelio
          • Mar 2016
          • 9
          And for me, I don't want to upgrade yet...
          My environment is: Centos 7.3, Postgresql 9.5.1, Zabbix 3.0.8
