Postgresql Agent - Wrong Connection Numbers
  • torsten.brink
    • Jan 2025
    Hi Forum,
    I´m working on an integration to a Postgres server/database, integration itself is fine so far. But we´ve recognized that the connections reported in zabbix are just wrong from my point of view.
    In Zabbix itself we are 16 connections (total) reported (see image below):
    However when checking with pgAdmin tool, I query for the connections as well. By the way the query is from source code in github here: https://github.com/zabbix/zabbix/blo...ctions.sum.sql
    and from my point the queryy works totally fine. Please note I added line 5 and 8 in the screenshot below to make the issue more clear.
    So bottom line Zabbix is reporting 16 total connections, okay. But in fact Zabbix is only reporting it´s OWN connections and not the total connections of the server. This makes the total % value also wrong (8% vs. in reality 27%) and therefore required alarms will not be reported.
    My setup is:
    - Zabbix Server 7.2.0
    - Zabbix Agent2 - latest
    with the "PostgreSQL by Zabbix agent 2 active" template. I also tried the non-active template.. its the same issue.
    Any feedback / help is high likely welcome.
    Torsten
