installation problem 7.2 Debian 12
  • threepwood77
    • Jan 2025
    I need a hand.
    it's probably a mistake but I can't find it or I've made a mistake ...
    once I've installed Zabbix, when I connect to the web interface, the dashboard displays the following page:
    if I try to add a host, when I add it, it runs without stopping.
    I've tested Zabbix 7.2 with Debian 12, with Ubuntu 24.04, with a mondodb SQL database and postgresql, and in every case, I always get the same result !
    do you have any ideas ?
    thanks for your help.
