Zabbix Agent received shutdown request.
  • NgRox
    • Jun 2022
    • 45
    I have a problem with Zabbix-Agent. When servers restart, Zabbix-Agent (6.4.20) receives messages in log:
    5568:20250125:010907.854 Zabbix Agent stopped. Zabbix 6.4.20 (revision 114e4f42c15).
    5452:20250125:011128.824 Starting Zabbix Agent [HOST]. Zabbix 6.4.20 (revision 114e4f42c15).
    5452:20250125:011128.824 **** Enabled features ****
    5452:20250125:011128.824 IPv6 support: YES
    5452:20250125:011128.825 TLS support: YES
    5452:20250125:011128.825 **************************
    5452:20250125:011128.825 using configuration file: C:\Zabbix\zabbix_agentd.conf
    5452:20250125:011300.970 agent #0 started [main process]
    4568:20250125:011300.975 agent #2 started[listener #1]
    4672:20250125:011300.983 agent #3 started[listener #2]
    4704:20250125:011300.988 agent #4 started[listener #3]
    4564:20250125:011300.993 agent #1 started [collector]
    5420:20250126:012106.121 Zabbix Agent received shutdown request.
    5420:20250126:012107.145 Zabbix Agent stopped. Zabbix 6.4.20 (revision 114e4f42c15).
    5548:20250126:012253.004 Starting Zabbix Agent [HOST]. Zabbix 6.4.20 (revision 114e4f42c15).
    5548:20250126:012253.005 **** Enabled features ****
    5548:20250126:012253.005 IPv6 support: YES
    5548:20250126:012253.005 TLS support: YES
    5548:20250126:012253.006 **************************
    5548:20250126:012253.006 using configuration file: C:\Zabbix\zabbix_agentd.conf
    5548:20250126:012422.782 agent #0 started [main process]
    1596:20250126:012422.789 agent #1 started [collector]
    1592:20250126:012422.796 agent #2 started[listener #1]
    1456:20250126:012422.802 agent #3 started[listener #2]
    6296:20250126:012422.810 agent #4 started[listener #3]
    5516:20250127:012709.354 Zabbix Agent received shutdown request.
    5516:20250127:012710.363 Zabbix Agent stopped. Zabbix 6.4.20 (revision 114e4f42c15).
    5720:20250127:012849.188 Starting Zabbix Agent [HOST]. Zabbix 6.4.20 (revision 114e4f42c15).
    Can someone help-me?
    Zabbix 6.4.20
    Zabbix-agent install in Windows.
  • Answer selected by NgRox at 21-02-2025, 02:33.
    NgRox
    • Jun 2022
    • 45
    Result of Analyze:
    There was another collector running in parallel
    Uninstall the other collector resolved the problem
    • NgRox
      • Jun 2022
      • 45
      No, when restart server the service Zabbix start correctly.
      I don't know too.
      I'm analyzing
      • NgRox
        • Jun 2022
        • 45
        Result of Analyze:
