Zabbix schedule report generating fail
  • wisanpon
    • Jan 2025
    Hi.
    i found some error after install google-chrome like this
    • Cannot fetch data.: network.EventLoadingFailed event with ErrorText = 'net::ERR_CONNECTION_REFUSED' was received while loading dashboard.
ID:	498180​and not found any topic like this.
    please help to find out.
  • omar.cacciotti
    • Jul 2021
    • 25
    Same problem to me
    Poor documentation and log info imho
    • polancolj
      • Jan 2025
      Same problem to me
      • noone
        • Mar 2025
        Good evening!
        Could you add additional information regarding your Zabbix setup, e.g.: is it installed from packages, are the services installed on the same machine of different machine?
        Did you set all of the required parameters in the zabbix-server, zabbix-web-service config file, frontend url in frontend?
        The google chrome needs to be installed on the same machine as the zabbix-web service, expect if it is from container.
        If issue persists, please increase the zabbix-web-service DebugLevel to 5 and share the log file output.
