Discovery rule with HTTP Agent and converted JSON gives errors
  • mariusl
    • Aug 2024
    • 33
    Following up on my post in another thread, i'm having issues with properly handling converted JSON data from HTTP agent in a discovery rule.
    I am doing a simple request to an URL that returns a value in clear text, as example
    mydata=0
    I'm using the function in HTTP agent to convert this to JSON which returns
    {"body":"mydata=0"}
    Notice how it does not add an array.
    Using this, i'm getting multiple errors. Without defining any LLD Macros i get
    Cannot find the "data" array in the received JSON object.
    Adding a macro with JSONPath $.body or $..body gives the same error.
    Using JSONPath $.. gives
    Cannot process LLD macro "{#UNIT_ID}": jsonpath was unexpectedly terminated.
    I have also tried JSONPath $.* and $..*, both giving errors.
    There are no preprocessing steps added.
    I'm starting to think that the "Convert to JSON" should have wrapped the data in an array. Perhaps there is a bug?
    Anyone else have some suggestions to what i could try, or can point out what i may be doing wrong?
    Thank you!
