Zabbix 5.0.x Database restore
  • Aruzsi
    • Apr 2023
    My Zabbix DB was stopped working more than a year.
    Postgresql 12.
    Ubuntu 20.04
    Zabbix 5.0.x.
    In these days I tried to get back the configuration from the database.
    It was successful more or less. I dropped all trend and history data.
    I recreated a new DB under postgresql 14. The dtatabase is running.
    Today I tried to connect the zabbix_server and I got those lines:
    QUERY: CREATE TABLE IF NOT EXISTS partitions.history_p2025_02_08 (CHECK ((clock >= '1738969200.000000' AND clock < '1739055600.000000'))) INHERITS (history)
    CONTEXT: PL/pgSQL function trg_partition() line 37 at EXECUTE
    [insert into history (itemid,clock,ns,value) values (23265,1739038245,137507513,0),(23625,1739038245,1 37468148,7.5957959238138804);
    16973:20250208:191046.391 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: invalid input syntax for type integer: "1738969200.000000"
    LINE 1: ... partitions.history_p2025_02_08 (CHECK ((clock >= '173896920...
    ChatGPT said me: the clock is integer and the '' is wrong! Why happened this?
    How can I solve the problem?
    Before I restored the backup I used the schema.sql and it was made an empty zabbix DB. After that I used my backup.
    I don't know what is the problem? The zabbix_server was installed from factory deb package.
    Please help me!
    TIA,
    Ruzsi
  • Aruzsi
    • Apr 2023
    Some more information:
    Postgresql is not 12 it is 14 (and it will be 16 or 17 soon).
    Timescale 2.18.0!
    Zabbix server: 5.0.46
