Create trigger button only creates triggers in one specific host
  • kecerim
    • Feb 2025
    When i try to create a trigger in an unrelated host (or template) it either gets created in that specific host or if it already exists i get 'trigger already exists in'
  • kyus
    • Feb 2024
    • 211
    Can you explain further what is the issue? What you described is expected behaviour...
    If you want to create a specific trigger in multiple hosts you can create a template for that and attach it to all the desired hosts.
