Zabbix 7.2 API authentication problem from Powershell
  • Petr N.
    • Feb 2025
    Hi, after upgrade to Zabbix 7.2 our Powershell scripts stopped working, because we were using "auth" parameter for all requests (API methods) and that parameter was removed.
    I can successfully get auth token and then I use
    $header = @{ "Authorization" = "Bearer $authToken"}
    $response = Invoke-RestMethod $url -ContentType "application/json-rpc; charset=utf-8" -Method Post -Headers $header -Credential $credentials -Body ([System.Text.Encoding]::UTF8.GetBytes($jsonRequest))
    After that the
    $response.error​
    is
    code=-32602; message=Invalid params.; data=Not authorized.​
    So I created my own file inside Zabbix folder (/user/share/zabbix/ui) just to return HTTP headers to see, if the Bearer authentication hits Zabbix PHP code (running on Apache). I have previously added
    SetEnvIf Authorization "(.*)" HTTP_AUTHORIZATION=$1​
    to my apache2.conf
    To my surprise I get these HTTP headers
    HTTP_AUTHORIZATION = Negotiate YIIJAwYGKwYBBQUCoIII9zCCCPOg <shortened>
    HTTP_USER_AGENT = Mozilla/5.0 (Windows NT; Windows NT 10.0; en-US) WindowsPowerShell/5.1.14393.7693
    HTTP_HOST = zabbix.mydomain.tld​
    Notice the Negotiate authorization instead of Bearer
    If I run just
    $response = Invoke-RestMethod $url -ContentType "application/json-rpc; charset=utf-8" -Method Post -Headers $header -Body ([System.Text.Encoding]::UTF8.GetBytes($jsonRequest))
    (ommiting the
    parameter) I get response:
    Invoke-RestMethod :
    401 Unauthorized
    Unauthorized
    This server could not verify that you
    are authorized to access the document
    requested.  Either you supplied the wrong
    credentials (e.g., bad password), or your
    browser doesn't understand how to supply
    the credentials required.
    which seems to me as Apache error message and not from Zabbix.
    So my question is, how do I authenticate to Zabbix from that Powershell script ?
    FYI we are using HTTP authetication to Zabbix UI, hence the Negotatiate authentication. Would some URL rewrite work (changing the Authorization header on Apache) ?
  • Petr N.
    • Feb 2025
    UPDATE:
    According to this question https://www.zabbix.com/forum/in-russ...api-powershell I tried to use session with a cookie to authorize to Zabbix API
    $zabbixDomain = "https://" + $ZabbixServer
    $session = New-Object -TypeName Microsoft.PowerShell.Commands.WebRequestSession
    $cookie = New-Object -TypeName System.Net.Cookie
    $cookie.Name = "zbx_session"
    $cookie.Value = $authToken
    $session.Cookies.Add($zabbixDomain,$cookie)
    I can see, that the cookie is set on my test page inside Zabbix web site
    HTTP_AUTHORIZATION = Negotiate YIIJAgYGKwYBBQUCoIII9j <shortened>
    HTTP_USER_AGENT = Mozilla/5.0 (Windows NT; Windows NT 10.0; en-US) WindowsPowerShell/5.1.14393.7783
    HTTP_COOKIE = zbx_session=7b3e68a959b43f47df0a224fdc8a6692
    but it makes no difference, the result is always the same
    It's not clear to me, whether the cookie name should be "zbx_sessionid" as in the linked problem, or just "zbx_session" which is written in the documentation https://www.zabbix.com/documentation/7.2/en/manual/api (if I understand it correctly)
    I have tried both but neither works. Do you have a working example how to use the session cookie to authorize yourself to Zabbix API ?
    Btw. the Zabbix account I'm using to authenticate is shown as "online" in Zabbix UI with recent last logon datetime so I don't think there's any problem with the account. I can get the token just fine. My problem is, how to use it.
    • Petr N.
      • Feb 2025
      UPDATE 2:
      Authentication with the cookie seems to be a dead end. Back to the Bearer authentication, I got another idea, which is a bit of hack (workaround) - set no authentication for just one file (api_jsonrpc.php) in Apache and leave the rest of the site with default (Kerberos) authetication. And I succeeded. The key part of the Apache config is:
      <Directory "/usr/share/zabbix/ui">
             <Files api_jsonrpc.php>
                 AuthType none
                 Order allow,deny
                 Allow from all
                 Satisfy any
             </Files>
      </Directory>
      I added that part inside our zabbix.conf file as follows:
      <VirtualHost *:443>
              LimitRequestFieldSize 65536
              LimitRequestLine 65536
              LimitRequestFields 1024
              ServerAdmin webmaster@localhost
              ServerName zabbix.mydomain.tld
              DocumentRoot /usr/share/zabbix/ui
              <Location />
                              Options FollowSymLinks
                              AllowOverride None
                              AuthType  GSSAPI
                              AuthName "Kerberos Login"
                              GssapiCredStore keytab:/etc/apache2/security/zabbix.keytab
                              GssapiBasicAuthMech krb5
                              require valid-user
              </Location>
                      AuthType none
                      Order allow,deny
                      Allow from all
                      Satisfy any
                  </Files>
              </Directory>​
      # other config here
      <VirtualHost>
      With that config in place I was able to use the Bearer authentication I wrote earlier
      $response = Invoke-RestMethod $url -ContentType "application/json-rpc; charset=utf-8" -Method Post -Headers $header -Credential $credentials -Body ([System.Text.Encoding]::UTF8.GetBytes($jsonRequest))​
      I still wonder what is the recommended way of accessing the API if I wasn't able to change Apache configuration (and therefore couldn't use the Bearer authentication header). Previously used auth parameter seemed perfect to me and I haven't found anywhere mentioned why it has been removed.
      • levon74
        • Aug 2021
        Petr, you saved me days of troubleshooting, I had the same issue as you and building the header did the trick (haven't touched the zabbix config though), thank you for that.
        And a good question, if that's how Zabbix is expecting the API authentication to be used, would be interesting to hear from them or find it in the docos.
        Thanks again.
          • 5008
          Cookie is used only if queried from UI, by javascript or widget..
          External script is not using it... as long as I undertand docs... There you either use user.login to obtain that token or generate one in UI and use it.
          • Petr N.
            • Feb 2025
            I tried to use the cookie because I wasn't successful authenticating with the Bearer token authentication. My problem wasn't obtainging the token (user.login works just fine), but using it (when I added Authorization header with the Bearer token, it was overriden by Kerberos (Negotiate) authorization to the Apache server). I still hope there would be an alternate authentication mechanism other than sending the Authorization header (maybe some alternative HTTP header), because in my opinion making an exception for just one file in site authorization on Apache is a hack (temporary workaround).
              • 5008
              Well, actually we use the same way... users come through gssapi authorization in apache (zabbix.company) and for API we use completey other webserver (zabbix-api.company) .. But that was intentionally set up already long time ago, not related to any of this topic..
              In other instance we went from apache to nginx and SAML... there is no issue to use same frontend as it does not interfere there... you still can use local auth for users there...
