Zabbix Agent 6.0.33 Installation on Solaris 11.4
  • ChrisQCK
    • Nov 2023
    • 11
    Hi All,
    After referring to multiple sources (webpage, forum posts, Zabbix Installation Steps for Unix-like system), I have distilled the steps into the one listed below. Since the system is on Solaris 11.4, I thought it would be proper to manage it using SMF. I have completed all the steps but somehow the service stuck at maintenance.
    The installation steps are as below.
    System Info :
    1. Zabbix Server 6.4.18; RHEL 8.10
    2. Remote Server : Solaris 11.4 on SPARC, Zabbix Agent 6.0.33
    01. Download the Agent here : https://cdn.zabbix.com/zabbix/binari...openssl.tar.gz
    (Note: Or your can also visit the official download page here : https://www.zabbix.com/download_agents).
    When you extract the tarball, you'll get 3 files : zabbix_agentd, zabbix_get & zabbix_sender.
    02 Copy the files to the respective directory as below :
    # cp zabbix_agentd /usr/sbin/
    # cp zabbix_get /usr/local/bin/
    # cp zabbix_sender /usr/local/bin/
    03. Create Zabbix Group & User, then add the user to the group.
    # groupadd zabbix
    # useradd -c 'Zabbix agent' -d / -g zabbix -s /usr/bin/false zabbix
    04. Create directory to store configuration file and copy configuration file into the directory.
    # mkdir /etc/zabbix
    # chmod -R 755 /etc/zabbix
    # cd /etc/zabbix/
    # cp -v /path/to/file/zabbix_agentd.conf /etc/zabbix/
    Note: zabbix_agentd.conf (Modified from default .conf file to Linux)
    LogType=file
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=512
    Server=xxx.xxx.xxx.xxx # Zabbix server IP Address
    ServerActive=xxx.xxx.xxx.xxx # Only needed if you want to enable Active Check
    05. Create log file directory and log file.
    # mkdir /var/log/zabbix
    # chown -R zabbix:zabbix /var/log/zabbix
    # touch /var/log/zabbix/zabbix_agentd.log
    # chown zabbix:zabbix /var/log/zabbix/zabbix_agentd.log
    06. Configure SMF (Service Manangement Facility)
    a. Create manifest directory
    # cd /var/svc/manifest/application/
    # mkdir zabbix-agent
    # chmod 755 zabbix-agent
    # chown root:sys zabbix-agent
    b. Copy the manifest to the directory.
    # cp /path/to/file/zabbix-agentd.xml /var/svc/manifest/application/zabbix-agent/
    c. Restart the Manifest-Import service to import the manifest.
    # svcadm restart manifest-import
    d. Verify if service is running.
    # svcs zabbix-agentd
    Note: SMF Manifest are created by executing the command below then modifying section as necessary.
    # svcbundle -o zabbix-agentd.xml -s service-name=application/zabbix-agentd -s model=daemon -s start-method="/usr/sbin/zabbix _agentd -c /etc/zabbix/zabbix_agentd.conf"
    <?xml version="1.0" ?>
    <!DOCTYPE service_bundle
    SYSTEM '/usr/share/lib/xml/dtd/service_bundle.dtd.1'>
    Manifest created by svcbundle (2025-Feb-20 16:31:49+0800)
    <service_bundle name="application/zabbix-agentd" type="manifest">
    <service name="application/zabbix-agentd" version="1" type="service">
    The following dependency keeps us from starting until the
    multi-user milestone is reached.
    <dependency name="multi_user_dependency" grouping="require_all"
    restart_on="none" type="service">
    <service_fmri value="svc:/milestone/multi-user"/>
    </dependency>
    <exec_method name="start" type="method" timeout_seconds="300"
    exec="/usr/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf"
    The exec attribute below can be changed to a command that SMF
    should execute to stop the service. Use svcbundle -s
    stop-method to set the attribute.
    <exec_method name="stop" type="method" timeout_seconds="300"
    exec=":kill"/>
    A duration property group is not needed.
    <instance name="default" enabled="true"/>
    <template>
    <common_name>
    zabbix-agentd
    <loctext xml:lang="C">
    </loctext>
    </common_name>
    <description>
    Zabbix Agent for Solaris v6.0.33
    The application/zabbix-agentd service.
    </loctext>
    </description>
    </template>
    </service>
    </service_bundle>
