Zabbix trapper Problem not getting data
  • Dolyak
    • Jan 2014
    Hello all!
    I am having a problem with trying to setup zabbix trapper on my zabbix 2.2 server. I can't get my app-server to send data to my zabbix-server with the zabbix-sender command. I have made an item on the zabbix server with the below configuration. The item says its enabled for the app-server as well. It looks to me like the zabbix-sender is getting to the zabbix server but for some reason the zabbix server is not accepting the data. The only change i have made from default zabbix_server.conf is to add 10051 listenport and startTrapper=5 do I need to add anything else to it? also the zabbix server log does not show anything, but i have not put in debug yet. Any help would be really great! Thank you
    Config for zabbix_server.conf:
    ListenPort=10051
    StartTrappers=5
    Item on zabbix server:
    Name data check
    Type zabbix trapper
    Key data.check
    Type of information txt
    Applications newdata
    On the app-server page:
    Template App newdata Service: data check data.check 90 Zabbix trapper newdata Enabled
    Zabbix sender String:
    /usr/bin/zabbix_sender -vv -c /etc/zabbix_agentd.conf -s "data check" -k "data.check" -o "50"
    Error I am getting:
    zabbix_sender [56468]: DEBUG: answer [{
    "response":"success",
    "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000051"}]
    info from server: "processed: 0; failed: 1; total: 1; seconds spent: 0.000051"
    sent: 1; skipped: 0; total: 1
    Tcpdump of the connection successfully making it to the zabbix-server from the app-server
    tcpdump -i eth0 port 10051 | grep app-server
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
    15:25:33.586366 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [S], seq 3470354256, win 14600, options [mss 1460,sackOK,TS val 1061567524 ecr 0,nop,wscale 7], length 0
    15:25:33.586413 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [S.], seq 2051021343, ack 3470354257, win 14480, options [mss 1460,sackOK,TS val 1102476942 ecr 1061567524,nop,wscale 7], length 0
    15:25:33.586677 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [.], ack 1, win 115, options [nop,nop,TS val 1061567524 ecr 1102476942], length 0
    15:25:33.586721 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [P.], seq 1:6, ack 1, win 115, options [nop,nop,TS val 1061567524 ecr 1102476942], length 5
    15:25:33.586736 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [.], ack 6, win 114, options [nop,nop,TS val 1102476943 ecr 1061567524], length 0
    15:25:33.586974 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [P.], seq 6:125, ack 1, win 115, options [nop,nop,TS val 1061567524 ecr 1102476943], length 119
    15:25:33.586992 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [.], ack 125, win 114, options [nop,nop,TS val 1102476943 ecr 1061567524], length 0
    15:25:33.587429 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [P.], seq 1:6, ack 125, win 114, options [nop,nop,TS val 1102476943 ecr 1061567524], length 5
    15:25:33.587493 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [FP.], seq 6:108, ack 125, win 114, options [nop,nop,TS val 1102476943 ecr 1061567524], length 102
    15:25:33.587688 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [.], ack 6, win 115, options [nop,nop,TS val 1061567525 ecr 1102476943], length 0
    15:25:33.587849 IP app-server.44519 > zabbix-server.zabbix-trapper: Flags [F.], seq 125, ack 109, win 115, options [nop,nop,TS val 1061567525 ecr 1102476943], length 0
    15:25:33.587870 IP zabbix-server.zabbix-trapper > app-server.44519: Flags [.], ack 126, win 114, options [nop,nop,TS val 1102476944 ecr 1061567525], length 0
  • nobodysu
    • Sep 2016
    • 84
    zabbix_agentd.conf contents? Preferably whole.
